Phidgets 8/8/8 in RR
  • Phidgets 8/8/8 in RR
    I have the phidgets 8/8/8 board and i would like to use, besides the voltage/temp sensors, also the digital io portion, how can i do this in RR ? Also could a level change on a dig. input change say a red circle to a green circle in a skin ?
    Jan
    Not doing carpc anymore
    Skippy76 added support for controlling the relays... regarding the digital IOs I have no info about it... I've always planned to get my hand on one of them boards to add everything it can do, but never did get one..
    Ride Runner RR's Myspace
      dopehead: If you are able to provide the test for us (i.e. you are responsible for testing) I shall provide the update.
      IN theory I guess you may want a digital input to do 1 of two things:
      - as an indicator
      - as an action (e.g. if the state changes)
      What do you think? Also, Guino, are you ok with me implementing this?
      06 Volvo XC90
      Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
      Car PC downloads: http://carpc.harteveldt.com/
        skippy>certainly i can test this, i have the board on my pc in the house at the moment with the latest RR release right now, and i have implemented voltage and temp readouts in my skin already.
          If you can implement it (have the means to), I'm all for it since I don't have the hardware myself..
            Ok,
            Dopehead: You need to give me some detailed requirements of what you want.
            06 Volvo XC90
              Skippy, ok so what i would really like to see is generic support for the digital io ports of phidgets cards, like the analog sensor inputs via PHIDXX/f2c/volt commands, and then the ability to change the skin graphic according to the state of the input (true/false - on/off) Also controlling the digital output ports would be nice. I'm not sure what kind off info you need more than this, so i did a little screen dump to illustrate what would be nice.
              Jan
                oh, and also i was looking through the source of rr, and can't seem to find the phidgets related stuff, what module is it placed in ?
                  look in modRoadRunner in the indicator proc... do a search for phid...
                  06 Volvo XC90
                    i found it ok. looks very simple, but somehow it needs some fundamental changes to implement i/o ports, now of course i have not seen the source for the relay functionality you have implemented yet, could be you did most of the work already :-)
                      nope, should be pretty easy....
                      06 Volvo XC90
                        sounds good, let me know when you have something for me to test.
                        Jan
                          Skippy, i actually fooled around with my new mini joystick from phidgets yesterday and did a little piece of code thats lets you use the joystick as a mouse :-) maybe you can use it for something RR related ?
                          http://www.mp3car.com/vbulletin/showthread.php?t=64518
                            Skippy, I actually have digital input working in RR now, i just need to figure out where to place initialization of the interfacekit and the OnChange events for input updating, also currently its just statically linked to input number 1 on the card,and with a skin command of PHIO this of course should be done like the temp sensors....PHID01,PHID02 i am thinking PHIDIN01,PHIDIN02 and so on for the Indicator commands.
                              Got it working for all 8 digital inputs now, starting with the outputs tomorrow i think, i got my amps connected to the card and working :-)
