Sending IR Singals with RR & USB-UIRT?
  • Sending IR Singals with RR & USB-UIRT?
    Okay, I want to control my head unit using IR Signals. I already have GIRDER up and running with a USB-UIRT and a IR stearing wheel remote. But I need to find a way to send a trigger to Girder from RR. (I can already control my head unit with Girder and the USB-URIT)
    So in the end, I want to push a button on the screen which would have RR send Girder an event, then Girder would produce the IR code via the USB-UIRT.
    Any Ideas guys?
    use Girder's event.exe. Make the RR button do something like this.
    "RUN||C:\Program Files\girder\event.exe your_event_string -silent"
    The -silent is there so that you don't get a Command Prompt window.
    Just verify the syntax.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
      Let me know if this works... want to do the same with my DTT TV Receiver..
      My Project Site
        Girder newbie here... I want to control my HU via girder/RR so that I can use steering wheel to control HU volume rather than Winamp/Windows volume. Can someone please verify my plan?
        Previous setup: BMW steering wheel press "volume up" button sends IBus command "VOL+" to RR, which increases the volume coming out of winamp. This currently works great.
        Desired setup: Steering wheel press "volume up" button sends IBus command "VOL+" to RR, RR in turn translates this into executing girder event.exe (as specified above) for sending IR command to my HU to increase volume. I would put this "VOL+" translation in the ExecTBL.ini file at the c:/Program Files/Road Runner level, and it would go something like this: "RUN||C:\Program Files\girder32\event.exe VolumeUp -silent", which if I set up Girder correctly, should use my USB-UIRT to transmit the IR code for increasing the volume to the HU, and WOULD NOT increase the WinAmp/Windows volume.
        Is this right?
        My install log
        My "selling entire system" thread
          Well, after trying what I proposed above, I'm not getting anywhere. I've put the following entry into my ExecTBL.ini:
          "VOL+","RUN||C:\Program Files\girder32\event.exe VolumeUp -silent"
          When I press the volume up button in my skin (which is mapped to "VOL+"), I get nothing. Here's my GML that I'm working with:
          I'd appreciate any suggestions on what I'm going wrong.
          My install log
            NM, figured it out - the entry goes in the top-level ExecTBL.ini, and it should be:
            "VOL+","RUN;event.exe|VolumeUp -silent"
            My install log
