Hide window frame of winamp visualization window
  • Hide window frame of winamp visualization window
    Hi,
    how do I hide the frame of the visualization windows of winamp?
    like in this pic:
    When I turn on the visualization I just see also the frame of the window with also the title, the resiza button in bottom right etc. I'd like to just show the visual.
    Thanks!
    2005 BMW X3
    • Motorized Lilliput 629GL-70P
    • 3Ghz Commell LV-672
    • 300G HD / 1G RAM
    • Griffin Powermate
    • Motorola MPX220 + Leather craddle
    Use a CLASSIC skin, and make sure that the vis is propperly set in RRConfig.
    Ride Runner RR's Myspace
      Hi Guino, thanks for you help!
      I tried both but still same problem.
      As you can see I'm using the classic skin.
      I used simply Milkdrop visual to test it so I could not use a wrong name for the visual. The fact that as I enable the visual from RR it resize and pan the visual window means it recognized the name right?
      2005 BMW X3
      • 300G HD / 1G RAM
      • Griffin Powermate
        Does everyone is using it with the frame?
        2005 BMW X3
        • 300G HD / 1G RAM
        • Griffin Powermate
          nobody?
          2005 BMW X3
          • 300G HD / 1G RAM
          • Griffin Powermate
            please search.. when using milkdrop, there's an option INSIDE MILKDROP to turn off the border: "Integrate with winamp".
              Thanks Guino
              will look better for it. I just mentioned Milkdrop as an example but know I understand that anyway it's an option that I have to find in the visualization.
              2005 BMW X3
              • 300G HD / 1G RAM
              • Griffin Powermate
