Still problems after re´nstall Windows
  • Still problems after re´nstall Windows
    Lately my RR was running veerrryy slow, and hangs fot no reason.
    Today i did a fresh install:
    Formatted harddisk
    Installed Win XP Pro
    Installed Windows updates
    Installed Flash
    Installed Winamp 2.9
    Installed RoadRunner
    Updated Roadrunner
    After that i started RR (default skin).
    As soon as i pressed 'Music' the program hangs.
    Fresh restart, another try, now i pressed the internet button in RR, again hangs.
    Then i installed LS3.0 skin, hoping it would be better, but it gives the same problem. It takes 'bout 4 secs. to change the logo in RR into the clock. RR doesn't respond to enything, sometime's when im lucky it works after 4-5 reboots. When i play music and i want to go back to main menu, it starts hanging again...
    I really dont know what to do... Someone please help? Thanx!
    Specs:
    P4 1.8GHz
    512MB DDR
    Onboard video
    Onboard sound
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
    Just did CPU check... CPU is 100% when clicking a button. I just waited a moment, and after 30sec finaly the music screen appeared. Opening playlist, and playing music was normal. Opening VIS was also good, but when i went back to main menu, and pressed Music again, he hangs again...
    When i start RR, CPU is 'bout 2-4%. When i move my mouse OVER any button, CPU goes to 100%... At that time i didn't click anything...
    Strange... Even NFS Underground 2 runs great on this machine...
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
      Goto a non flash screen or try freedom with flash 9, Promise you it wil work specialy if u use non flash
      my TURBO! Altezza!
      ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
        http://www.mp3car.com/vbulletin/showthread.php?t=45529
        Ride Runner RR's Myspace
