Skippy any way to use netdetect to auto download weather info for RR?
  • Skippy any way to use netdetect to auto download weather info for RR?
    Any ideas?
    Sound Stage
    Eclipse|MTX|Infinity
    RR.. Needs this bad. Alot of us have wifi at home and at work. I would use RR more if that data was loaded on every wifi connect. Heck I would donate $100 to anyone that makes a plugin to auto update.
    1999 Black Camaro Z28
    Lilliput 701-Athlon 64 2800-512ddr-40gb-Earthmate GPS-iNav-RoadRunner-Wifi
    Installed.. Finally
      interesting , with wifi_man plugin i think is possible.
      BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
      RRTube ==> [View/Download Youtube Videos]
      WifiMan ==> [Wifi Manager]
      RRec ==> [Audio Capture]
      If You Want To Be Given Everything, Give Everything Up ...
      Bird York -- In The Deep --
        Go get them 100 bucks El C..you can come up with something!
        OLD SYSTEM (DEAD)
        Intel D945GCLF2 Dual Core ATOM
        Lilliput 7" 629GL 2008 LED Backlight
        BU-353 USB GPS Receiver / iGuidance / IGO8
        M2-ATX Power Supply
        RideRunner Front End / Various Skins
        Windows XP SP3
          Not just weather, gas prices too
          Installed.. Finally
            careful what you say.. i'm a whore like that lol. If you're serious i'll crack open the source monday.
            Live mp3Car Facebook Chat
              this is not that hard. just go find that program that creates a file everytime that an internet connection is found. then do
              "EXISTS;file.txt" and have it execute something. shouldnt be that hard. ill try tomorrow.
              EDIT: autonetdetect? is this not already done?
              http://www.mp3car.com/vbulletin/road...netdetect.html
              ^^^^download that, run chucksonline.exe at RR startup, and then put in exectbl.ini:
              Code:
              "ONLINEPINGON","RELOADWEATHER||UPDATEgpsGAScommand"
              ill split the hundred with chuck and whoever else made it. thanks. haha
                You could run this from NetDetect,should do the trick.
                P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                  Code:
                  Any luck on this? I want to start my car and all the online stuff update. Simple as that.
                  Installed.. Finally
                    I have something like this working. It checks for an internet connection every so often (whenever you want)...then it will run a command. The command can be in either RR or external commandline (3 of each). Then it can be configured to execute that command every so often(3 of each). Also disconect commands and an online indicator. This little project started because ping doesn't work accurately for me(half of what I connect to via wifi blocks ping even when connected). So, this script doesn't use ping, it checks the size of an online file. I don't know if I'd call it finished yet, but I've ran it a couple of weeks at a time checking every 4 seconds, reloading weather every 250 checks If I ever get it done I'll post the script in the plugins.
                    current ini: (some of the variables need to be changed to make more sense)
                    [online status]
                    SETVAR=ONLINESTATUS
                    URL=http://image.weather.com/web/blank.gif
                    RUNAPPCONNECT1=
                    RUNAPPCONNECT2=
                    RUNAPPCONNECT3=
                    RRCMDCONNECT1=RELOADWEATHER
                    RRCMDCONNECT2=
                    RRCMDCONNECT3=
                    RUNONCE1=
                    RUNONCE2=
                    RUNONCE3=
                    RUNONCERR1=
                    RUNONCERR2=
                    RUNONCERR3=
                    RUNAPPDISCONNECT1=
                    RUNAPPDISCONNECT2=
                    RUNAPPDISCONNECT3=
                    RRCMDDISCONNECT1=
                    RRCMDDISCONNECT2=
                    RRCMDDISCONNECT3=
                    RUNDISCONNECTONCE1=
                    RUNDISCONNECTONCE2=
                    RUNDISCONNECTONCE3=
                    RUNDISCONNECTONCERR1=
                    RUNDISCONNECTONCERR2=
                    RUNDISCONNECTONCERR3=
                    SLEEPTIME=4000
                    EXECUTEEVERY=250
                    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
                    MediaLaunch for RR
                    Online Check for RR
                    Locker for RR
                      Thats cool.^. RR plugin developers need to consider momentary internet access when write them. I know some plugins store data to a file, but alot do not. What Im trying to say is that RR needs a unified netcheck and datastore for plugin devels to use.
                      Installed.. Finally
