hibernate wakeup todo list
  • hibernate wakeup todo list
    I start everyday with my hibernated carpc waking up when the car starts. I know that RR can do certain things when RR starts up, but is there a way to do things when it wakes up from hibernate, already running?
    For instance, here are 2 examples. every morning, I'd like it to do 2 things...
    1. run the flash made by DiNASTY in mauri's thread,
    2. run the weather refresh command to pull the latest weather off the net.
    I know for #2 I can hit the "refresh" button, but I'm looking for a slightly more automatic procedure.
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    There are other programs besides RR that can run files (or batch files/vb scripts if you want multiple things done) - search some common key words and you'll find some quickly (resume suspend hibernate run program, etc)
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Originally posted by xdjxklusivex
    i think every thread is now a whoreing thread
      I was going to use the ONRESUME command to trigger mauri's flash movie. It should also do the weather update too if I'm understanding it correctly. Try adding this to the ExecTBL.ini
      "ONRESUME","RELOADWEATHER"
      Beer is proof that God loves us and wants us to be happy Benjamin Franklin
        DiNASTY, that's brilliant! But...
        I found there is a precedence problem. When the computer wakes up, RR comes on, and I assume immediatetly carries out the instructions. Problem is, it takes about 30 seconds for my network to realize it's supposed to wake up & connect. So I'm not connected for like 30 seconds after wakeup.
        I don't know if that's my XP, my network setup, or a wakeup issue (I haven't done my homework yet). I wonder if there's a...(searches skincommands.txt).
        Look what I found:
        Code:
        /, (TMR) Timer event
        /, Seconds
        TMR,XXX
        The above defines the number of seconds after loading the screen RR will wait to
        execute the "TIMER" event that can be defined in ExecTBL.INI so a command is executed at such time.
        But I'm not sure how to get it to work. Does this code need to be in a skin?
        What goes in exectbl.ini?
        Conceivably, I could put the command in my menu.skin, and have a code in exectbl.ini like this to switch to menu.skin every resume:
        "ONRESUME","MENU"
          the command to load menu.skin is MAIN, and RR doesn't re-load a skin that is already the current one so you'd have to load a new screen. in any case, I'm implementing an ONLINE event that will allow you to execute a command like reload weather when the network becomes live, so you'd not have to do any funky stuff.
          Ride Runner RR's Myspace
            Sweet! I'll wait then.
            *uses the time wisely to go make a donation to guino*
              Sounds perfect
                I have test this string for my custom indicator by DiNASTY:
                "ONRESUME","LOAD;EXTERNAL_GPS.skin;cinture.swf "
                EDIT:"cinture" its the name of the flash indicator , but don't work after the resume.
                I use start automatically the "GPS" as before application of defaut .
                Help
                Mauri
                  Help
                  Mauri
                  Another test with :
                  "ONSUSPEND","MAIN"
                  "ONRESUME","LOAD;EXTERNAL_GPS.SKIN"
                  But don't work ...
                  Any suggestion ?
                  Mauri
