new phoco 1.6
  • new phoco 1.6
    i have just upgraded to the new phoco 1.6. it works perfectly on its own, but when i let RR load phoco it has an error, common language runtime debugging services. if i load it manualy then RR, everything works, but does not hid the minimize button.
    is it a problem with RR or phoco?
    I can confirm this. Same here
    You just gotta love these new versions
      The problem is that Phoco need to start within the phoco directory, and this seems a RR bug. The solution is to start Phoco before with an script, and then wait and start RR.
      An example script is:
      cd "c:\program files\PhoneControl.NET"
      start Phonectl.exe -remoteNoDesign
      wait 25
      cd c:\rr
      start rr.exe
      exit
      Another problem with this new versión is that phoco had changed the phonebook location, and then rr can't create the rr phonebook.
      regards
        wait 25
        cd c:\rr
        start rr.exe
        exit
        regards
        If you want to speed it up a bit, look out for the "Overall startup time:" in your PhoneCtlLog.txt. Take this time, add a second and use that time for the "wait" command.
        This time should be somewhere in the range of 4 to 11 seconds, depending on the computers speed and kind of connection (a cable connection is way faster than a Bluetooth connection).
        Skinning to go... VisualDesigner2!
          Have you added more phone support to this release?
          PROGRESS 95%[//////////]Complete - Software configurations
          Current Task: Just adding on...
          Needed:wireless keyboard/mouse
          My Carputer Blog
          Car System Site
            Go to my forum and have a look into the Version Tracking thread if you want to know what has changed.
              Zorro, I just went to your website and noticed that you had a notice about license and the old version expiring etc. I just wanted to say that the short notice for expiring support on your old version is way too short. I don't believe that anyone should ever force the consumer to upgrade their product especially at such a short notice. Ending support for your old product the same month you release your new product is way too aggressive. Please reconsider.
              NOTE: I don't own any license yet as I'm still trying to get my phone to work with your product. I'm speaking from my perspective as a consumer.
              My Carputer Blog
              Car System Site
                a quick OT question: is PhoCo's main Meedio plugin updated and kept up-to-ate meaning is it working well with PhoCo 1.6?
                  There has nothing changed in the Remote Interface so it shall be compatible.
                  As a side note: I've release the Meedio plugin source code (VB6) for developers. So developers who like to play around can register on my forum and request a developer group access.
                    Even if I wanted to, I can't support 1.5 anymore because I lost my master key for the licensing due a crash (stupid things sometimes happen).
                    Bug fixing and new features can be only applied to the new version.
                    Customers who have a valid license for 1.5 will still be able to use it but if they want to take advantage of the new features they have to upgrade. There's is a free license key replacement program.
                    So, the bottom line is: I do care about my customers.
                      Zorro I'm not saying you don't care but the message could put a negative taste a customer's mouth!!
                      My Carputer Blog
                      Car System Site
                        Bugger, an update inside a week of buying 1.5.1
                        Am I understanding correctly that my old license will NOT work on 1.6?
                        John
                        My Nissan 200SX @ Silverstone
                        NOW SADLY WRITTEN OFF!
                        My Car's spec list + pics
                        Stealth CarPC fab'ing...
                          Right.
                            Uff... I am getting these when launching Meedio with (both) plugins installed - one after each other (see screenshot). I can get to plugin, if I surpress both error messages, but then UI does not do anything (does not interact with PhoCo).
                            Standalone PhoCo app works fine.
                              Have a look here: http://zhorvat.dyndns.org/PCForums/S...px?PostID=1566
                              It's also less OT.
