What is the start command for Satellite Radio in RR config?
  • What is the start command for Satellite Radio in RR config?
    What is start command in RR config that allows the satellite radio to start when RR starts? I know "GPS" starts GPS and "RADIO" starts FM radio, etc.
    I tried using "XM" but that caused RR to stop responding for some reason. I also tried "SAT RADIO" but that seemed to do nothing.
    To load XM, the startcommand should just be "XM" as you said. If that's giving you trouble for whatever reason, try "LOAD;XM.SKIN"
    Its not the cards you're dealt, its how you play the hand!
    Originally posted by ryuandwings
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
      Going to try it now....
        That command too caused RR to stop responding on launch. RR freezes at the splash screen. Seems to be something with the letters "XM" in it.
          dumb idea, but make sure you have the XM skin in you rr skin directiry....
            I checked that earlier, and the skin is in the directory. I am using the BMV2 skin and XM skin works fine there. I just want RR to launch SAT RADIO when I turn the PC on and RR comes up.
              There's a reported issue when trying to launch XM immediately after starting RR. Probably because of the delayed process of starting up the XM receiver. I have not had a chance to sort that out yet simply because I don't have an XM tuner setup anywhere to test it. To prevent issues, you should start RR, then manually start XM.. then if you hibernate/resume, RR should restart the XM device on the last used station.
              Ride Runner RR's Myspace
                Got it, thanks for the answer. I am certain you'll fix this in future releases. Thanks for all you do, I really appreciate it.
