Keypad navigation and focus
  • Keypad navigation and focus
    ive done a little search but nothing aswered my question
    when using the keypad to navigate,
    when a program is embeded it will stele the focus from RR making the shortcut keys nolonger work
    is there a way to make RR check and regain focus
    or a line to add to the shortcut key to make it get focus??
    thanks mick
    View My Blog
    Click for 2GB FREE on-line storage!
    This is the intended functionality -- exactly so you can use the keyboard on your embedded application. A simple ALT-TAB can do the trick. Now your "issue" is probably because you don't have a FULL keyboard available and my problem is that the same way that you're asking for RR to steal focus away, I'll have other people asking for RR NOT to steal the focus away. All I can recommend is for you to assign a shortcut key on the embeded application or use a hot-key application to try and assign a key globally for the simple purpose of simulating ALT-TAB for instance.
    Ride Runner RR's Myspace
      is there any way to make the RR commndsa global so they work regardless of it being focused or not?
      View My Blog
        Use Girder.
        iGMon - Integration between iGuidance and Road Runner
        CFX - Skin for Road Runner
          is there anyways u could put this in as a setting, something like
          keepfocus=true|flase ??
          i will have a go at girder too..
          thanks
          View My Blog
