flash animation at boot up
  • flash animation at boot up
    Can anyone help me?
    What i am wanting to do is use either media car or road runner as my front end for my car pc. i have found a place that shows you how to have windows boot directly to the front end instead of into windows.
    what i am wanting to do is have it boot directly into front end but play a
    flash animaiton first. So when you turn on the PC it plays the animation first and then boots to the front end application.
    Does anyone know how to do this or what i am talking about?
    Do i have to have somehow add the flash animation to the front end application or can they be seperate?
    Thanks everyone
    i would love to no the same mate
    [B]Car Computer 98%[|||||||||-]
    Install Plan 100%[||||||||||]
    Styling 20%[||--------]
    Install 0%[----------]
      I'm wondering if you can maybe boot into the flash document, and then have it load the program once it has completed the animation. Not sure how this could be accomplished, but I'm sure action scripting could do it if properly executed. I'll look into it. Any ideas on if this would work?
      Carputer Status: Half-Way There....
      On the list:
      Accele 8" Touchscreen, Viper 5000, Accelevision 6-in/6-Out Video Switcher, Shuttle 51G (donated) P4, 512mb, 320GB, Centrafuse 1.6!
      V.le Raffaello Sanzio... ahh Firenze!
        not sure if that would work or not, but u could ask guino to add the flash object type to the loader screen.
        beer replenishment fund
        mp3car live search
          i can do flash but i am not that up on scripting the flash, i am sure that there is a way that the script can open a program, but how i have no i dea
            or... you could make a flash animation that plays fullscreen and compiled as an .exe file. Then just stick it in your startup folder or make a .bat file that runs that then RR.
            mp3car live search
              You could try this:
              Flash Form Application
              Liquid_Smoke's Idea makes the most logical sense, especially if it's pretty quick, and you run the .exe to run full screen on top. That's what makes the most sense.
              On the list:
                thanks
                i might try to create an .exe file or the .bat file.
                i didnt know if there was a way to combine the flash file or movie into the program of like road runner or media car.
                Thanks for all the help
                  This can all be done very simply within flash by using fscommands to control the flash 8 projector program. basically, just create your animation and place this script on the main time-line at the beginning:
                  Code:
                  onLoad () {
                     fscommand ("fullscreen", true);
                  and at the end of the movie (when your animation is done playing) place this script:
                  Code:
                  onFrame (25) {   //frame 25 was used as an example end frame
                     fscommand ("exec", "C:\\Program Files\\RRpath");  //Path to RR.exe (use double slashes)
                     fscommand ("QUIT");
                     stop();
                  Now just export your movie to .exe (projector) and place a shortcut to the exe in your startup folder or however you like to launch programs at startup. This should work with SWF4 or later.
                  Beer is proof that God loves us and wants us to be happy Benjamin Franklin
                    Good call DiNASTY. Sounds like that could work as well.
                    Good work.
                    On the list:
                      wow DiNASTY I will give this ago thank you
                        Code:
                        onLoad () {
                        Code:
                           fscommand ("QUIT");
                           stop();
                        DiNASTY, thanks but i am using flash professional 8 and when i copy and paste your code into it, it doesnt seem to reconize the "onload" or the "onframe" part, i might be doing it wrong.
                        has anyone else got it to work?
                        thanks
                          Hi mate i just found out that it will not work like this as it is outside the flash security sandbox, I am working on it now and hopfully will find a way if i do then i will tell you how and try and give you the files needed for you to see
                            ok, thanks
                              hi ok i sorted it, infact i liked it so much that i thought i would do a little tut for how to do it here
                              http://www.mp3car.com/vbulletin/showthread.php?t=70496
                              any questions please ask there
