MCE 2.0 Skin question regarding GPS
  • MCE 2.0 Skin question regarding GPS
    I have and found too much information and now I am confused. I am using CdRsKuLL's MCE 2.0 skin and it rocks! I have everything working as I need for the exception of the GPS, when I launch MCE and select Nav, I get the freedrive to come up, but it populates the entire screen and not within the skin for MCE. I have tried the same with Mapmonkey and same results.
    I have tried making the gps prog external, menu in the rr.config and same problem. Is there a fix for this??
    Appreciate any assistance. Thank you.
    niccard007
    Project: 1998 BMW 323IC
    Installation: Never done
    VIA EPIA MII12000/1ghz Ram/7" lilli/M1-ATX/Leadtek BT GPS/Cisco 350 G PC Card/
    in your gps settings.. in rrconfif and put it on external and make sure the name you have for the GPS Window name is FreeDrive not freedrive .. has to be spot on, this will then grab FD's window and embed it correctly
    cdr
    Follow me on Twitter
    http://www.FreeICE.co.uk
      Thank you!!!! Worked like a charm!
