Different shortcuts on different screens
  • Different shortcuts on different screens
    Hey all,
    is it possible to have different shortcuts for one key on different screens?
    e.g. when i press "enter" on the audio player it toggles between play, pause and when i press "enter" in the gps skin it brings up the menu?
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
    I don't know about toggling on the same screen (unless you use girder or something), but you can have different functions for different screens. I think the keytbl.ini file has the documentation for it...
    Stealth OEM spyder
    1204 dot net!
      associate your keys to new commands on keytbl.ini, then define your new commands on a per-screen basis in exectbl.ini..
      Keytbl.ini:
      37,"COMMAND1"
      ExecTBL.ini:
      "COMMAND1","PLAY",audio_player.skin
      "COMMAND1","STOP",menu.skin
      Ride Runner RR's Myspace
        WHAT! no way
        i have been tring to do this for so long..
        View My Blog
        Click for 2GB FREE on-line storage!
          with this way do u have to put in every skin u use to make it work the short cut work in all skins?
          does that make sence?
          View My Blog
            Great stuff....!!!!
            2+2=Quattro
            Audi S6 2.2 Turbo
            RNS-E Headunit
              WOW - this changes everything...
              My install log
              My "selling entire system" thread
                You can specify commands to execute on ALL or on specified screens.. it's all the job of ExecTBL.INI:
                "COMMAND1","PLAY",menu.skin
                "COMMAND1","STOP",audio_player.skin
                "COMMAND1","MUTE"
                Above, COMMAND1 will execute MUTE in any screen except for menu.skin and audio_player.skin -- where it has other functions. This will work as long as your "default" command is the last, I mean, is defined after (below) the lines that define it on a per-screen basis.
