Need help skinning volume buttons-redirect
  • Need help skinning volume buttons-redirect
    Ok I got the skinning program and whatnot and I need a head start if anyone could on redirecting the volume buttons to change a different bar in the volume control rather than the default "Master Volume"
    I've tried opening ini and whatnot and i dont see anything about it in the program. Thanks!
    Again with RRConfig -- look for the option that says "map master volume to" .. that will allow you to select a line other than master to control.
    If you just want to change the line of a specific slider, then you just have to open the .skin file and change the slider code for the slider. All possible slider codes are listed in skin commands.txt
    Ride Runner RR's Myspace
      I changed the map master volume to: rear speaker and it worked! Thanks a lot!
