Navigon NCK 4 in RR
  • Navigon NCK 4 in RR
    Hi guys,
    Very nice frontend
    Is there any way to use the external GPS soft Navigon 4 NCK, because when I try setting it up in RR it doesn't load and it would be nice to have it in RR because of the OSK which I need to input the address.
    Here is my rr.ini extract:
    showid3browse=false
    gpsmode=2
    gpsport=3
    mapmonkeypath=C:\Program Files\NAVIGON GmbH\NCK 4.0 Notebook\NCK.exe
    gpspath=C:\Program Files\NAVIGON GmbH\NCK 4.0 Notebook\NCK.exe
    gpsname=NAVIGON GmbH
    exitmode=0
    showicons=true
    showextensions=true
    titlesafter=-
    listfollowssong=true
    I tried different methods but none will load the navi soft
    Please help
    VIA Epia M10K
    1 Gig RAM
    200 Gigs HD 3.5" ATA
    M2-ATX
    CTF-700 7" TFT TS
    Haicom GPS Sirf III
    Morex Case
    Car2PC
    WiFi-g
    BMW--SarCP
    ▬▬▬▬▬▬▬▬▬▬ H/W
    ▬▬▬▬▬▬▬▬▬▬ S/W
    ▬▬▬▬▬▬▬▬▬▬ Dash
    ▬▬▬▬▬▬▬▬▬▬ Install
    Read the how to embed FAQ.. follow the process to verify if the window title is correct.. you may be runnint the application on the background and not seeing it.. you should also set gpsport=0 during your tests, so that RR doesn't prevent your GPS app from using it. if it still doesn't load, make a .bat file like:
    C:\NCK.bat
    with this inside:
    @echo off
    c:
    cd \Program Files\NAVIGON GmbH\NCK 4.0 Notebook\
    NCK.EXE
    Then set the gpspath to:
    gpspath=c:\nck.bat
    Ride Runner RR's Myspace
      Thanks mate , gonna check the FAQ asap. I did but probably on the wrong keywords
      When I get the specs for the ini file I'll post them here for future reference.
      I'm of to and with some luck I'll be when it works.
      Cya
      PS: I love those wacky emoticons
      VIA Epia M10K
      1 Gig RAM
      M2-ATX
      CTF-700 7" TFT TS
      Haicom GPS Sirf III
      Morex Case
      Car2PC
      WiFi-g
      BMW--SarCP
      ▬▬▬▬▬▬▬▬▬▬ H/W
      ▬▬▬▬▬▬▬▬▬▬ S/W
      ▬▬▬▬▬▬▬▬▬▬ Dash
      ▬▬▬▬▬▬▬▬▬▬ Install
        Well I tried with Winspector but the problem is that navigon starts in full screen mode and doesn't have a titlebar
        Also tried it with the bat file but no joy.
        This is what I can get from the window list and properties in Winspector.
        Properties for window 0x00190154
        Item Value
        Class Name Afx:400000:b:10011:6:e201fb
        Text NCK 4.0
        Rectangle 0, 0, 800, 600
        Size 800, 600
        Client Rectangle 0, 0, 800, 600
        Client Size 800, 600
        Styles WS_OVERLAPPED
        WS_VISIBLE
        WS_CLIPSIBLINGS
        0x00049152
        StylesEx WS_EX_LEFT
        WS_EX_LTRREADING
        WS_EX_RIGHTSCROLLBAR
        ID 0
        Properties
        Class specific none
        Owner EXE C:\Program Files\NAVIGON GmbH\NCK 4.0 Notebook\NCK.exe
        rr.ini:
        gpsmode=2
        gpsport=0
        gpspath=C:\NCK.bat
        gpsname=!Afx:400000:b:10011:6:e201fb
        exitmode=0
        showicons=true
        showextensions=true
        Am I forgetting something? I checked the taskmanager after clicking GPS in rr but no mention of NCK in there, the bat file works ok by itself.
        VIA Epia M10K
        1 Gig RAM
        M2-ATX
        CTF-700 7" TFT TS
        Haicom GPS Sirf III
        Morex Case
        Car2PC
        WiFi-g
        BMW--SarCP
        ▬▬▬▬▬▬▬▬▬▬ H/W
        ▬▬▬▬▬▬▬▬▬▬ S/W
        ▬▬▬▬▬▬▬▬▬▬ Dash
        ▬▬▬▬▬▬▬▬▬▬ Install
          U won't get NCK embedded in RR because it has no static border...
          The only thing u can try is to add the following code to the top of your nck.ini:
          [Dimension]
          Width=800
          Height=550
          OffsetX=0
          OffsetY=0
          That will start NCK in 800x550 in the top left corner. U can optimise these values for your own belongings
          2+2=Quattro
          Audi S6 2.2 Turbo
          RNS-E Headunit
          Helix HX400=AXTON Amp
          Audi Doorspeakers and 15" JBL in Sparewheel Hole
          19" Alutec Alloys, ABT-Silencer, FK-Suspension
            you should listen to dbassix.. but just for your information, when a class name is all numbers like you posted, normally those numbers CHANGE from time to time everytime you run the application.. so you may want to look for that and see which numbers change and don't include that in the setting..
              I've been playing around with the class names but still no luck
              Even been trying integrate explorer and calc just to see rr would load it, but didn't work. Can someone see what I did wrong or give me an example to load a standard windows app in the gps window, so I can see the result in rr gps window?
              Here is my extract:
              gpsmode=2
              gpsport=0
              mapmonkeypath=
              gpspath=C:\WINDOWS\explorer.exe
              gpsname=!ExploreWClass
              exitmode=0
              showicons=true
              showextensions=true
              titlesafter=-
              Cheers
              VIA Epia M10K
              1 Gig RAM
              M2-ATX
              CTF-700 7" TFT TS
              Haicom GPS Sirf III
              Morex Case
              Car2PC
              WiFi-g
              BMW--SarCP
              ▬▬▬▬▬▬▬▬▬▬ H/W
              ▬▬▬▬▬▬▬▬▬▬ S/W
              ▬▬▬▬▬▬▬▬▬▬ Dash
              ▬▬▬▬▬▬▬▬▬▬ Install
                I'll be damned, just tried with the BM skin and it loads Navigon perfectly Guess Simplistique is a bit buggy not rr
                Now just gotta find out how to put an OSK icon on the top bar in BM ;-)
                VIA Epia M10K
                1 Gig RAM
                M2-ATX
                CTF-700 7" TFT TS
                Haicom GPS Sirf III
                Morex Case
                Car2PC
                WiFi-g
                BMW--SarCP
                ▬▬▬▬▬▬▬▬▬▬ H/W
                ▬▬▬▬▬▬▬▬▬▬ S/W
                ▬▬▬▬▬▬▬▬▬▬ Dash
                ▬▬▬▬▬▬▬▬▬▬ Install
                  I'm also trying to get navigon to work embedded with roadrunner. I've changed the the window name in navigon 4.0 and it runs but the navigon screen is to big for rr screen how can i fix this
                  Forget it if fixed the window problem but how can I keep the audio control buttons in the windows
                  See here the fx
                  See here what I want
                    as you set follow string inside your nck.ini
                    [Dimension]
                    Width=800
                    Height=525
                    OffsetX=0
                    OffsetY=0
                    your nck application is showing in a box like 800x525, starting on position 0,0
                      In the butom of your picture you see the control butons which skin are your using. I've already fixed the windows problem but I think you are useing a differend skin
                        Let see some screenies when you get this sorted, Im interested to see what the PC app looks like, could only find PPC screenies on net.
                        Skinbedder might be an option to help with embedding & skinning Navigon
                        My Nissan 200SX @ Silverstone
                        NOW SADLY WRITTEN OFF!
                        My Car's spec list + pics
                        Stealth CarPC fab'ing...
                          hi
                          i got an prob to run nck embedded too.
                          but my prob is any time i press next or any other rr buton in my nav skin rr is in front of nck and i got to go back at main screen and return to nav skin to see nck again how can i fix it? i already tryed to make my skinpics in .gif with invisible colours but rr always sets the invisible colour into pink
                            You need to set a Clipping area the same size of you application area.
                            SOmething like this.
                            /, A, x, y, w, h, color;RGB
                            A,209,92,581,396,0
                            /, C, x, y, w, h
                            C01,209,92,581,396
                              Check out what I did over here
                              http://www.mp3car.com/vbulletin/show...hlight=navigon
