Iguidance embedded problem
  • Iguidance embedded problem
    Quick question for Guino, or whoever might know what the problem is.
    On my externalgps.skin I have an application window that embedes Iguidance and some basic play, next, mute etc buttons at the bottom of the window. My problem is, whenever I push one of those buttons the Iguidance screen above them flickers (refreshes, redraws, etc). In other words, it goes completely white for a second, then it comes back to normal. This happens every time I push a button. How can I make it stop doing that ?
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
    create a clipped area the same size as your iguidance window.
    /, (C) Clip window Region (Road Runner Only)
    /, x y w h
    CXX,XXX,XXX,XXX,XXX
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
      add a clipping area the same size and position of the iGuidance window and it will stop flashing.
      >> well, 1.5 sec to late.
        Yeah but I have a little problem with that. I thought about that too....
        Problem is, with my skin I have have the visualization running in the backround and I already have a clipped area on the main menu and audio players skin for the vis to see through. IS there any other way... or not ? :/
        Current Setup
        Nexus 7 Tablet
        Built in head unit
        Brutus 1500Watt Amp
        Two Boston 12" subs
          You want to have Vis and iGuidance on the same screen?
          iGMon - Integration between iGuidance and Road Runner
          CFX - Skin for Road Runner
            Vis and Navigation....Who is watching the road for ya?
              Who cares... It's what I want, and I think it looks good. The vis in my skin is only 30 pixels high anyway.
              Current Setup
              Nexus 7 Tablet
              Built in head unit
              Brutus 1500Watt Amp
              Two Boston 12" subs
                What's the problem ? you can add as many Clipping definitions as you want in a screen... just add a "Cxx,xxx,..." line for the application area and leave the one for your vis in there too.. RR will slice and dice the window in as many pieces you ask it to.
                Ride Runner RR's Myspace
                  I know.... but I kinda want the realestate the vis is gonna take for Iguidance In other words, I would clip the window where Iguidance is without anyproblems, but can I can be sure that the vis is always going to stay BEHIND the Iguidance window when I'm on the GPS screen... and stay in front of it when I switch back to the audio player skin ?
                  Current Setup
                  Nexus 7 Tablet
                  Built in head unit
                  Brutus 1500Watt Amp
                  Two Boston 12" subs
