RR, FD and window issue
  • RR, FD and window issue
    Hello,
    I have a little problem with integrating FD.
    I designed an address skin from into RR to FD
    I call this skin with:
    "LOAD;ADDRESS.SKIN;address;FreeDrive.exe;FreeDrive ||SendMsg;FreeDrive;address","address"
    the problem is that I start FD within RR normally the the window with the cities and the streets didn't appears, as you can see at the image below.
    If I start FD Previous to RR (at windows starting), and after that, I start RR, the the window appears OK. This involve that I must have FD allways started to work.
    Do you know what the problem is?
    thanks and Regards
    I had the same problem, but it is fixed in 1.0
    2+2=Quattro
    Audi S6 2.2 Turbo
    RNS-E Headunit
    Helix HX400=AXTON Amp
    Audi Doorspeakers and 15" JBL in Sparewheel Hole
    19" Alutec Alloys, ABT-Silencer, FK-Suspension
      I have this problem with 1.0 and also with 1.0 preview update 1
      thanks
        I assume you are actually loading FD on external_gps.skin BEFORE you load your address.skin screen ? otherwise you have to place the entire path to FD on your load command cause just FreeDrive.exe won't cut it.
        Ride Runner RR's Myspace
          Same problem here, as well in 1.0 preview and 1.0 preview update 1. I think it is an FD issue, because FD version 0.9 didn't have this problem.
          Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
          Software: Roadrunner, Mapmonkey/Freedrive
          My Car PC project
          FD & MM voices
            Remember that its possible to do an FD address skin and embed RR commands into it with 1.0. I know its only a workaround.
            Will see if we can do anything about the skinning issues.
              Ye I load FD as external_gps skin all works except only this.
              I know that I can do the skin into FD, the black window with the osk is FD, but doing this way I have more space for the window.
              thanks and regards
                didnt one of the FD releases change the window title name? Not sure about this, just kind of remember something did this. FYI i dont have this problem.
                beer replenishment fund
                mp3car live search
