Problem with the volume level slider
  • Problem with the volume level slider
    If I barely touch the volume level slider on the main RR screen, it immediately moves the volume level slider, located under "windows/accessories/entertainment/volume control", all the way down to the bottom (off) position. It acts like the RR slider is way, way too sensitive.
    Any ideas?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    what happens if you use the volume+/- buttons ? You may have to check/change the "master map volume" setting in RRConfig.
    Ride Runner RR's Myspace
