switchbutton without a button?
  • switchbutton without a button?
    Hi guys,
    I want my powermate using girder to switch skins from AUDIO to SIRIUS using the same action on the powermate (doubleclick) so I double click the powermate, it switches to Audio skin. Doubleclick again it switches to Sirius skin.
    Cant use the new command to loop back to previous screen as whodwho's voice software is not compiled to G's latest release.
    Is there an easy way on the RR side of things to accomplish this? Could use a girder plug in, but it would screw up the whole script.
    Sound Stage
    Eclipse|MTX|Infinity
    Not sure what you are doing but guino just added a command to recall last skin “LASTSCR”
    And it will switch back and forth
    2001 S10 ZR2
    Chucks Skin - to old
      Chuck,
      OK LASTSCR works sort of. I need to load the SIRIUS skin and the audio skin, but I have not been to the SIRUIS skin. Is it possible to point to the 2 skins that LASTSCR will switch between to start off?
      "LASTSCR","LOAD;AUDIO.skin||LOAD;SIRIUS.skin" I know this does not work but maybe this makes it more clear of what I am trying to do.
      Sound Stage
        I cannot think of a way to do this right now but if guino adds the setswitch that I have been posting about you could do this easily
        “AUDIOSIRIUS”,”SWITCH;AUDIO||SETSWITCH;2<<SIR IUS|| SETSWITCH;1”
        HAY guino is there a way to do this now?
        2001 S10 ZR2
          Ok put this in your ExecTBL.ini file and it should work
          "AUDIOSIRIUS ","SIRIUS",Audio_Player.skin
          "AUDIOSIRIUS ","AUDIO",Sirius.skin
          "AUDIOSIRIUS "," AUDIO "
          2001 S10 ZR2
            Exactly what I was going to suggest -- then add a girder command to execute "AUDIOSIRIUS"
            Ride Runner RR's Myspace
              I love you guys
              Sound Stage
