Problem with Girder and RR
  • Problem with Girder and RR
    I downloaded the girder file in the sticky.. Sometimes when I hit my programmed "Next" and "Previous" keys RR will go to next / previous song and then sometimes it will FAST FORWARD / REWIND the song?? I even changed it from being "RRNEXT" to just "NEXT".
    Any ideas?
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    Did you remove powermate.exe from the startup?
    Check out my install pics; http://mp3car.com/vbulletin/showthread.php?t=70842
      Huh? From what startup?
        what is the device you are using? Is it a powermate?
        Sound Stage
        Eclipse|MTX|Infinity
          Sorry, I assumed that you were using a powermate.
            No, it's a Jensen steering wheel remote with a serial IR device.
              are you sending ONLY "RRNEXT" or are you sending any commands before it like: "MYCMD||RRNEXT" ? RRNEXT/PREV should always switch songs, unless you're executing them in a "repeat" state -- which should not happen in girder unless you're sending out a command with a "!" in front of it.
              Ride Runner RR's Myspace
                I downloaded the gml file in the sticky. I then did "learn event" for the Audio > Audio Commands > Rrnext and Rrprev.
                It would skip through like 4 or 5 songs so I then changed the "Antirepeat wait time [ms]" to 500.
                  Any ideas?
                  Thanks!
                  Your not alone, i recently started having the same problem. Im gonna try to use an older version of RR to see if its a problem with the new RR.
                    I have the same steering wheel device. I am having problems setting this up aswell. I have the remote working fine in Frodoplayer but i cant seem to figure out how to get RR to accept the commands. Can someone help?
                      here's something you can try, instead of using the RRNEXT/RRPREV commands defined in the GML file.. you can set the command to execute: "exec RRNEXT" and "exec RRPREV" -- the exec.exe application is provided in RR's binary package.. this should at least give you an alternative to try.
