RR comes back to different screen on resume from Hibernate
  • RR comes back to different screen on resume from Hibernate
    I thought for sure there was another post like this but I searched 6 pages of results with no luck. My music DOES resume when the PC comes up. The only issue is that RR comes back to the main menu instead of where it was. I always hibernate from the audio player. Shouldn’t it come back to the audio player?
    My Work Thread:
    http://www.mp3car.com/vbulletin/showthread.php?t=72552
    Source switcher for Lill
    http://www.mp3car.com/vbulletin/show...d=1#post841007
    Check ExecTBL.ini file in RR and skin specific for ONRESUME event.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
      So I need that line to look like this?
      "ONRESUME","LOAD;AUDIO_PLAYER.SKIN"
      My Work Thread:
        I don't know why you guys hibernate. I have mine setup to S3 Standby.
        If I put my key in the ignition it comes up in 5 sec. and no problem with battery draining. I left the car sit for 4 days and it starts up just fine and comes back to the last screen I had displayed.
        I don't have anything in ExecTBL.ini under "Onresume"
        But if you need to I would use "ONRESUME";"MENU;Audio_Player.skin"
          That really doesn't help solve the problem, does it? I personally don't have the S3 option on my Biostar M7NCG 400 ver 7.2 motherboard. Many users don't have that option on their board either. This has been debated a ton. I would also like to know how to configure RR when resuming from hibernation.
          Biostar M7NCG 400 ver 7.2 AMD Mobile Athlon 1.1GHz (@ 1GHz), Kingston PC2700 512mb WD 80gig HD Custom Case Opus 150W PS Lilliput 7" TS D-Link DBT-120 BT D-Link DWL-G122 WiFi Holux GR-231 GPS nLited XP Pro iGuidance RoadRunner frontend
            Thjere should be no entry of onresume if you want it to continue where it was. That is my setting and should be the default setting.
            remove any ONRESUME lines from exectbl.ini in the RR directory and check there isn't one in the skin directory as well.
              Its a mystery then because my execTBL.ini looked like this:
              "ONRESUME",""
              I looked in the skin dir but nothing there either.
              My Work Thread:
                OK, I found the problem. I don’t have a solution yet but I am half way there.
                I knew this problem had started around the time I put the gamma control in the startup folder.
                So I went out, closed gamma control, took it out of the startup folder, set RR to audio player and turned key off. Bingo, it comes up to the audio player.
                Then I started gamma control, set RR to audio player and turned key off. On resume RR comes up to menu.
                So I know what is causing it. I just don’t know why, or how to have my cake and eat it too (read: get resume to work right but have gamma control also).
                My Work Thread:
                  You probably have gammacontrol auto-switch the skin for you (night/day), so for whatever reason it's "switching" the skin when resuming from hibernation -- this may be something for you to post on the gammacontrol forum.
                  Ride Runner RR's Myspace
                    Yes, that was it exactly. I had the “change setting in RR” checkbox in gamma control set. Once I took that out, all is well.
                    I would never have known it was changing skins since there isn’t a night skin out for Triton yet so I have day and night set to same skin.
                    My Work Thread:
