phoco call_in.skin not working BAV2
  • phoco call_in.skin not working BAV2
    Hey guys
    i have been trying to get phoco to work properly with the BAV2 skin, it works so for as i have my powermate that sends chars to RR and exectbl.ini has these :
    "EXEC","dial_phoco",phoco.skin
    "MODE","exit",phoco.skin
    "RIGHT","DOWN",phoco.skin
    "LEFT","UP",phoco.skin
    "RIGHT2","VOL+",phoco.skin
    "LEFT2","VOL-",phoco.skin
    "EXEC","ACCEPT_CALL_PHOCO",call_in.skin
    "MODE","HANGUP_CALL_PHOCO",call_in.skin
    Exec is mapped to single press on powermate and mode to the long click.
    now, if i am in the audio player and a call comes in , the call_in skin comes up, but when i hit the powermate it pauses the sound and doesn't answer the call like i mapped it in exectbl.ini......any ideas as to why ?
    Not doing carpc anymore
    nobody has this problem, is everyone using touchscreens for phoco ? i can't get it to respond to any mapping for the call_in.skin in exectbl.ini it seems like even if the call_in is displayed, its still the buttons defined in the underlaying skin that are working.
      does it work right with the BMV2 skin ? if so, it's probably something wrong on the skin itself.. if not then maybe a setting or bug..
      looking at your settings, I'd try just this instead of the xxx,call_in.skin lines:
      The above won't work well if you have the same commands mapped on other screens UNLESS they're the very last lines starting with "EXEC" and "MODE"..
      Ride Runner RR's Myspace
        i think maybe i am using an old bmw skin, will try the bmw2 from rrdownloads
          no difference from bav2, one thing i noticed is, in the phoco.skin the button for answering is "dial_phoco" and in call_in.skin it is ACCEPT_CALL_PHOCO, the last one i can't find in skin commands.txt.....so which one is it ?, i have eliminated the possibility that it is the powermate, cause pressing the same key it sends on the keyboard makes no difference, the referenced key in
          keytbl.ini : 189,"EXEC" and 190,"MODE" combined with exectbl.ini :
          does not work, every other skin works fine with my keytbl/exectbl commands, just not phoco.skin and call_in.skin
