Roadrunner crashing on startup
  • Roadrunner crashing on startup
    I'm at the stage in my system testing where I'm trying out the latest version of Roadrunner to use as a frontend. I've tested the app on one of my workstations and it started up and ran perfectly.
    When I transferred it to my carPC (EPIA MII-12000, onboard video, win2kpro svcpk4, 512 RAM, onboard sound, MTSVO-SC LCD with touchscreen drivers installed, DirectX 7.0, running at 800x600 and trying the Kuo Clean Skin) it crashes on startup. I get the error:
    "rr.exe has generated errors and will be closed by Windows. You
    will need to restart the program.
    An error log is being created."
    Anyone know what a likely cause of this might be? I have winamp 2.95 installed on the system, but so far I have left the Winamp settings in roadrunner blank. (I have not pointed it to the winamp path). On startup, it seems to be crashing right at the point where the text says "Starting winamp ..." After it crashes, my windows taskbar has disappeared from the screen.
    I added the winamp path to the rrconfig app, and RR still crashes, but winamp stays open on the screen after RR crashes.
    [EDIT:
    I tried changing the MII-12000 BIOS setting for display type from LCD to CRT, but this didn't make a difference.
    I also removed the MTSVO touchscreen and put a regular CRT monitor on the system to test if the touchscreen might have been causing the problem. Roadrunner still crashes on startup with a regular monitor.]
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
    can you post your rr.ini ? This type or error is very unusual.. you can also add this line to RR.INI and look at the debug log:
    debugmode=true
    Ride Runner RR's Myspace
      For testing, I just wiped out my entire RR directory and unzipped a fresh RR-binary copy into the old directory. I then ran the config, and set up the day/night skin settings, and saved the config. I then added the debugmode=true setting to the rr.ini file and ran RR. It crashed again. Here is the info:
      rr.ini (basically untouched):
      voice=false
      musicpath=Click here to set path
      videopath=Click here to set path
      dvdpath=Internal
      launchpath=Click here to set path
      winamppath=Click here to set path
      skinpath=D:\utility\roadrunner\Skins\800x600_clean _day\
      nightskin=D:\utility\roadrunner\Skins\800x600_clea n_night\
      mpcpath=Click here to set path
      screentype=4:3
      videoautohide=true
      videohidetime=4
      hidemouse=false
      albumart=*.txt
      useid3=1
      showid3playlist=false
      showid3browse=false
      mappointmap=1
      mapautozoom=true
      mapcountry=United States
      mapcity=
      gpsmode=3
      gpsport=0
      mapmonkeypath=Click here to set path
      gpspath=Click here to set path
      gpsname=
      exitmode=0
      showicons=false
      showextensions=false
      titlesafter=-
      listfollowssong=true
      resumemusic=0
      audiorepeat=off
      audioshuffle=off
      gammamode=2
      dateformat=Short Date
      timeformat=Long Time
      id3listformat=%title%
      id3browseformat=%title%
      mastervolmap=0
      listnumbers=true
      noformat=false
      hidewinamp=false
      visuname=MilkDrop
      overspeed=55
      scrollmode=1
      builtinvideo=true
      disableinternat=false
      locale=0
      hidetaskbar=false
      hidedesktop=false
      radiomode=0
      radioline=0
      lazytag=false
      allowallfreqs=false
      browsertype=1
      browserpath=Click here to set path
      debugmode=true
      And here is the debug.txt file:
      4/1/2006 11:33:46 PM: Start
      4/1/2006 11:33:46 PM: Master Vol: Master Volume/4
      4/1/2006 11:33:46 PM: GetLineControl Failed: 401
      4/1/2006 11:33:46 PM: No Treble Support
      4/1/2006 11:33:46 PM: No Bass Support
      4/1/2006 11:33:46 PM: Source: Wave=&H1008/1
      4/1/2006 11:33:46 PM: Source: SW Synth=&H1004/2
      4/1/2006 11:33:46 PM: Source: 3D Depth=&H100A/3
      4/1/2006 11:33:46 PM: No Mute for Source
      4/1/2006 11:33:46 PM: Source: Mic=&H1003/4
      4/1/2006 11:33:46 PM: Source: Line In=&H1002/5
      4/1/2006 11:33:46 PM: Source: CD Player=&H1005/6
      4/1/2006 11:33:46 PM: Source: Video=&H100A/7
      4/1/2006 11:33:46 PM: Source: Aux=&H100A/8
      4/1/2006 11:33:46 PM: Source: Phone=&H1006/9
      4/1/2006 11:33:46 PM: Source: PC Speaker=&H100A/10
      4/1/2006 11:33:46 PM: Source: Wave=&H1008/11
      4/1/2006 11:33:46 PM: Can't Open Source
      4/1/2006 11:33:46 PM: Winamp window not found.
      4/1/2006 11:33:46 PM: Shell: "Click here to set pathwinamp.exe"
      4/1/2006 11:33:46 PM: Winamp executable not found.
      4/1/2006 11:33:47 PM: Winamp window not found.
      It's strange that it's saying "winamp window not found" since I haven't configured the winamp path, but it looks like the error is being caused by something with the onboard sound: GetLineControl Failed: 401
      Hopefully this isn't too big a deal to figure out...
      '01
        I would strongly suggest to test it with Winamp/music/video paths setup.. RR should time out in 5 seconds after trying to start winamp.. but not crash.. the "failed" on the sound cards just means it doesn't support that feature..
        IMHO it sounds like you may have some hardware issue coming up at high CPU LOAD and/or intensive memory operations.. can you post information or a screenshot of the DETAILS of the windows error ?
          Where would the details of the windows error be found? The only thing in the crash window that pops up is what I posted above about "rr.exe has generated errors, etc etc" with either an "OK" or a "CLOSE" button (I can't recall which right now). There are no details beyond that.
          I don't think it's a CPU/RAM instability as the machine overall is extremely stable even under high load. I've had it running at close to 95% CPU load for extended periods while testing. I tested starting RR again with the winamp/music paths set, and I had the windows task manager open. The CPU usage doesn't go above 50% on RR starting up, and the memory usage doesn't go above 70Mb. The system at startup is using approx 50Mb RAM.
          This is the rr.ini file as it is now:
          voice=false
          musicpath=D:\music\
          dvdpath=Internal
          winamppath=C:\Program Files\Winamp\
          mpcpath=C:\Program Files\Windows Media Player\mplayer2.exe
          screentype=4:3
          videoautohide=true
          videohidetime=4
          audiofiles=mp3
          hidemouse=false
          albumart=*.txt
          useid3=1
          showid3browse=false
          mappointmap=1
          mapautozoom=true
          mapcity=
          gpsmode=3
          gpsport=0
          gpsname=
          exitmode=0
          showicons=false
          titlesafter=-
          resumemusic=0
          audiorepeat=off
          audioshuffle=off
          gammamode=2
          mastervolmap=0
          listnumbers=true
          noformat=false
          hidewinamp=false
          visuname=MilkDrop
          overspeed=55
          scrollmode=1
          builtinvideo=true
          locale=0
          hidetaskbar=false
          hidedesktop=false
          radiomode=0
          radioline=0
          lazytag=false
          allowallfreqs=false
          browsertype=1
          browserpath=C:\Program Files\Internet Explorer\IEXPLORE.EXE
          debugmode=true
          and this is the debug output:
          4/2/2006 11:47:17 AM: Start
          4/2/2006 11:47:17 AM: Master Vol: Master Volume/4
          4/2/2006 11:47:17 AM: GetLineControl Failed: 401
          4/2/2006 11:47:17 AM: No Treble Support
          4/2/2006 11:47:17 AM: No Bass Support
          4/2/2006 11:47:17 AM: Source: Wave=&H1008/1
          4/2/2006 11:47:17 AM: Source: SW Synth=&H1004/2
          4/2/2006 11:47:17 AM: Source: 3D Depth=&H100A/3
          4/2/2006 11:47:17 AM: No Mute for Source
          4/2/2006 11:47:17 AM: Source: Mic=&H1003/4
          4/2/2006 11:47:17 AM: Source: Line In=&H1002/5
          4/2/2006 11:47:17 AM: Source: CD Player=&H1005/6
          4/2/2006 11:47:17 AM: Source: Video=&H100A/7
          4/2/2006 11:47:17 AM: Source: Aux=&H100A/8
          4/2/2006 11:47:17 AM: Source: Phone=&H1006/9
          4/2/2006 11:47:17 AM: Source: PC Speaker=&H100A/10
          4/2/2006 11:47:17 AM: Source: Wave=&H1008/11
          4/2/2006 11:47:17 AM: Can't Open Source
          RR goes through the startup screen, then hits the "Starting Winamp..." portion. Winamp starts up properly and sits at the top-right of the screen, then RR crashes, and winamp stays open. After RR crashes, winamp is still functional: I can navigate its menus, open and close the playlist editor, equalizer, etc.
          '01
            I don't if this helps but I had a problem with RR crashing and it turned out to be the skin I was using. It was the slider code that was causing the issue.
              Yeah I thought about that, so I've now tried 5 different skins, all with the exact same result. I also tried booting into safe mode and running RR and it crashed at exactly the same point.
              I'm going to try connecting a PCI video card and seeing if it has something to do with the onboard video.
              I'm also going to try reloading windows from scratch and then loading RR as the first app, before any others, and seeing if I can track down some kind of conflict that way. However, I don't think it's a hardware issue.
              '01
                have you tried loading differen files on winamp before starting RR ? please let me know.. You may also try to disable ID3 support and/or delete main.* in the winamp\plugins\ml folder to see if it helps.. your INI seems pretty basic with no weird/advanced features.. so there's really no reason why it shouldn't work. The details for the windows error are normally displayed by clicking a "link" in the popup window with the ok/close buttons.
                  Well, I've been testing my system under windows XP SVC PK 2, and on a whim I tried Road Runner again. It worked without any problems, so it had to be something with my specific installation of win2k SVC PK 4. Strange.
                  One thing I've noticed though is that when I first ran Road Runner, I had winamp configured to show just the Track Title. I played around with it a bit, and then changed it to Artist - Album - TrackTitle. However, any albums from which I had already played a few tracks (when it was still configured for just TrackTitle) still showed just the TrackTitle, and did not display Artist - Album - Track Title.
                  '01
                    I have exactly the same problem right now.
                    ibus error
                    GTA skin
                      Did anybody get any where with this error?
                      RR works fine on my desktop running XP. But as soon as I run it on my win2k laptop it generates errors straight away.
                        i did it.
                        Not just rr, mediacar crashes too on win2k. Now i am using xp like everyone else here.
                        ibus error
                        GTA skin
                          interesting.. I used to run 2k on my desktop and never had an issue.. upgraded while back though.. but still have a 98SE install downstairs..
                            it may have to do something with service pack 4
                            there was a runtime error (80...)
                            ibus error
                            GTA skin
