execute vb scripts (feat req)
  • execute vb scripts (feat req)
    Hey guino, is it possible to allow RR to execute a VB script the same way as if i was pointing to an .exe. Right now it does nothing, not sure if this is a security issue or what not.
    thanks
    beer replenishment fund
    mp3car live search
    you can try cscript.exe script_name.vbs
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
      will give that try, never knew about cscript
      thanks
      mp3car live search
        ok, i kind of have this working, but with a few issues.
        1. there seems to be some odd thing happening when RR launches an app, im not sure why but its not the exact same thing as if i were to double click a file and launch it myself.
        When i run cscript and have it execute my vb script everything works fine and does what is expected. Since cscript is a command line tool, i wrote a autoIT script (compiled to .exe) to run cscript.exe and execute the vbscript. Again everything works fine and as expected.
        When i try to get RR to run cscript.exe it does not work. I know its launching the program but its not passing along the vbs to load. This was the main reason i wrote the autoit script and compiled to exe.
        Using that solution, RR still will not run the apps correctly. Using the autoITscript (compiled to .exe) RR will run the app, but for some reason cscript is trying to find the script in C:\Documents and Settings\liquid
        None of the scripts or anything anywhere says to look in that dir for anything, so im not sure why thats happening. Only happens when the app is launched by RR.
        any ideas?
        mp3car live search
          I think you must CD into the folder where your script is to ensure that it'll work. Your best bet is to write a BAT file that looks something like this.
          Code:
          c:
          cd \where your script is\
          start cscript.exe your_script.vbs
          Just save it as run.bat and execute it from RR.
            It's probably where RR is launching the script from (the skin folder)..
            Ride Runner RR's Myspace
              Code:
              c:
              ill give this a try, i didnt think of using .bat files (so hooked on autoIT ;] )
              the path issue is the only thing holding me up right now.
              also, for anyone else thay may be familiar with cscript.exe, is there a way to run it quietly so i dont see the console window flash?
              thanks everybody for the tips.
              mp3car live search
                no dice
                the bat file works when i click on it, but i get a cant find file error when its run from inside RR
                mp3car live search
                  RUNQ in RR is supposed to run the application "hidden" as in not show the console window (or any other window).. question is, how exactly are you, or have you tried to run it from inside RR ?
                    well ive been using just the standard RUN command pointed at the .exe
                    I know about the RUNQ but didnt use it as i couldnt get RR to run cscript.exe and launch the vbscript on its own (without using autoIT compiled .exe or .bat files that in turn launch cscript.exe)
                    So i guess the real original issue is i cant get RR to pass options or switches on to a program that its launching, actually ive never been able to do that or really fully understood the proper syntax to use, the example that mentions it in skincommands.txt only really has an example of embeding a window.
                    mp3car live search
                      you could try and formulate it like this:
                      cscript.exe c:\full\path\to\script.vbs
                      or even better put in the full path for both cscript and the vbs in autoit
                      That should do it I think
                        did you try this format: "RUN;COMMAND|PARAMETER1|PARAMETER2" ?
                          If the | doesn't work you can try " " as in
                          Code:
                          "RUN;cscript.exe" "your_script.vbs"
                          For some reason, the | doesn't work for me so I always use the above format when setting command line options.
                            Is it possible to do some VbScripting directly within RR, that would be a really useful feature
                              ive tried all of those, and they all work outside of RR.
                              mp3car live search
