Auto gamma switching in RR
  • Auto gamma switching in RR
    I'm quite confused about this - in several threads it mentions that built in day/night gamma switching is "under development" in RR, but the release notes of one version state that "RR now reads day/night values correctly from skin's general.ini", although I can't make it do anything with them? I then had a look at the latest source code, and there's a lot of bits from skippy76 which seem to reference auto gamma and GPS sunrise/sunset calculations, which read from certain values in rr.ini - but I can't find any documentation on this.
    So...does RR support any type of auto day/night gamma switching at the moment, and if so, what do I need to change/add to my rr.ini file to make it work? I know I could use gammacontrol, but I'm curious about what RR supports natively (if anything)?
    Any ideas - Skippy76 perhaps?
      I have the same questions.
      Assuming I don't use anything other tools but RR:
      Does it switch day/night skins on startup based on time in the skins ini?
      Does it switch day/night skins while running based on time in the skins ini?
      My Work Thread:
      http://www.mp3car.com/vbulletin/showthread.php?t=72552
      Source switcher for Lill
      http://www.mp3car.com/vbulletin/show...d=1#post841007
        if you download skippy's rr config you can use the auto gamma, however ever since daylight savings, the auto gamma has been changing 1 hour too early where i am. i've gone back to using gammacontrol by ol33l.
        my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
        wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
        company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
          Do you have a copy of Skippy's RRConfig? It's not on his site anymore!
          Otherwise, can anyone give me the relevant settings to add manually into my rr.ini file?
