Dynamic MUTE Command
  • Dynamic MUTE Command
    Hi Everybody,
    Trying to add a mic slider in the mixer to keep control of my microphone, and i am using these commands :
    "VOL;Mic" to control the Microphone level & "MUTE:Mic" to Activate/Deactivate the Mic
    I am able to control only the level of the Mic, but i can't activate or deactivate the Mic.... Seems the Mute command is not responding..
    This is my debug.txt :
    18/04/2006 19.38.29: Start -- Version: 06/04/2006
    18/04/2006 19.38.29: Master Vol: Master Volume/4
    18/04/2006 19.38.29: GetLineControl Failed: 401
    18/04/2006 19.38.29: No Treble Support
    18/04/2006 19.38.29: No Bass Support
    18/04/2006 19.38.29: Source: Wave=&H1008/1
    18/04/2006 19.38.29: Source: Sintetizzatore SW=&H1004/2
    18/04/2006 19.38.29: Source: Profondità 3D=&H100A/3
    18/04/2006 19.38.29: No Mute for Source
    18/04/2006 19.38.29: Source: Mic=&H1003/4
    18/04/2006 19.38.29: Source: Linea in ingresso=&H1002/5
    18/04/2006 19.38.29: Source: CD Player=&H1005/6
    18/04/2006 19.38.29: Source: Video=&H100A/7
    18/04/2006 19.38.29: Source: Aux=&H100A/8
    18/04/2006 19.38.29: Source: Phone=&H1006/9
    18/04/2006 19.38.29: Source: Altoparlante PC=&H100A/10
    18/04/2006 19.38.29: Source: Wave=&H1008/11
    18/04/2006 19.38.29: Can't Open Source
    18/04/2006 19.38.29: Winamp window not found.
    18/04/2006 19.38.31: Shell: "C:\Programmi\Winamp\winamp.exe"
    18/04/2006 19.38.35: Sim.WMSGs: 1
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Try it with a semi-colon or just a colon... I think there may be a typo in Skin Commands.txt
    Beer is proof that God loves us and wants us to be happy — Benjamin Franklin
      is't supposed to be ; ... nothing in .skin files that relates to codes uses : .. if the txt has a : then it's a typo.
      Ride Runner RR's Myspace
        Hi guys, thanks for your reply
        I had already tried with "MUTE;Mic" and i can confirm that does not work....
        I have also tested a different line, "MUTE;Wave" but the same...
        Others test at Home Pc with the same results....
        Guino, can you check the MUTE command?
        Thanks in advance for your help
        Fabio
        Travla C134
          Just tested it here with both the WAVE and the MIC line.. both worked perfectly ... my guess is that your sound card/drivers either don't support it or are being blocked by another application controlling the mixer. I'm assuming you're using the same card on you home pc as well ? do you have any other sound card to try ? also try clicking on the word "WAVE" on the mixer of the BMV2 skin to see if it mutes/unmutes it.
            My sound cards are different.. In the car it's a VIA VT1616 6 channels AC'97 Codec with Vinyl Audio Drivers, and at my home it's a SoundBlaster Live.
            Naturally the debug info from RR are different for each system, and i had considered the names of the lines on both systems....
            With every skin i can activate/deactivate the standard lines, but not the mic....
            I'm going to test with different drivers on both the systems..
            Anyways thanks a lot
            Fabio
            Travla C134
              Problem Found
              Ok guys,
              Finally i've found the solution...
              B,288,323,59,27,"MUTE;Mic" ----- THIS is working
              I,288,323,59,27,"MUTE;Mic" ----- THIS doesn't work!!!
              Guino, is this regular???
              Fabio
              Travla C134
                'I' are indicators -- only a handful are defined to handle the mute/unmute -- and you just specify the line name: "Wave", "Aux" etc..
                'B' are buttons -- the MUTE command only works on BUTTONS (Otherwise you'd see it under the indicator codes section of skin commands.txt).
