Two question about weather
  • Two question about weather
    I have two problem:
    1. What I do for weather icon visible?
    2. Why I view 3? C but not 3o C? (I don't view sign degree)
    Please, help.
    update your rr.exe
    2001 S10 ZR2
    Chucks Skin - to old
      Originally posted by Chuck
      update your rr.exe
      I have a last version, 06.04.2006.
        it works for me - so i do not know
        2001 S10 ZR2
          Where placemant a icon of sun, clouds and other?
            1-Check that you have the Weather folder with all the icons in it directly under RR's folder.
            2-The "o" symbol may not showing right because your Windows regional settings may be set to a locale (i.e. russian) which has a font that can't display that character. The only suggestion is to change the font used or change the Regional Settings.
            Ride Runner RR's Myspace
              O!
              The first item i fixed, but second Question: the "o" symbol get from Weather.com, or output by RR? In any locale correct output symbol with code "00B0". You are used it, or another code?
                that symbol comes from weather.com.. did you try different font/settings as I suggested ?
                  Yes, in english mode all correct, but in this case don't work some russian app. But can You make replace this symbol at next version?
