Problem with DIRECTION indicator
  • Problem with DIRECTION indicator
    The DIRECTION indicator on my system is showing not the next turn but the turn after that (one turn too far ahead)... What i mean is if the next turn is Left and the one after that is Right, then MapMonkey/Destinator shows a Left turn, but DIRECTION indicator shows Right turn...
    If i change the following line in modMMDirections.bas:
    NextManeuvertype = .ManeuverType(CLng(MM_CurrentManeuver + 1))
    and remove the + 1 it works as it should.
    Is it only my system or has anybody else seen this?
    This is with Scandinavian map and Metric/International settins (km/h)
    Anyone ???
      I don't think there's a lot of people using this feature. If you use it and think it's wrong, I can easily fix it with whatever you tell me it's right.
      Ride Runner RR's Myspace
        I believe somebody mentioned this problem. RR always shows one turn ahead of MM. Don't quote me on this though. I don't use MM so I don't know for sure.
        iGMon - Integration between iGuidance and Road Runner
        CFX - Skin for Road Runner
          When I used MM I have the same problem....I resolved it changed to Freedrive :|
            Guino, just remove the +1 on the line (see first post), this has been working great since I changed it...
              Guino, can you please change the following line in modMMDirections.bas:
              Please remove the "+ 1" to get MM direction indicator working, the line should read:
              NextManeuvertype = .ManeuverType(CLng(MM_CurrentManeuver))
                I'll remove it as soon as I have a chance.. Thanks.
