RR keeps on freezing!
  • RR keeps on freezing!
    sometimes if i load the music 1st it would stop responding!
    all the buttons stop working! and it takes a lot of CPU
    its the newest version from april 2006
    i am using the base skin
    any ideas?
    93 MAZDA MX6 KLZE (sold :( )
    2005 STI :)
    just a couple of things.. have you tried using a different version of winamp.. have you tried using a different skin.. Did t ever work fine on the system your running it on.. have you just upgraded your memory or anything like that ?
    CdR
    Follow me on Twitter
    http://www.FreeICE.co.uk
      its a new system
      i am using the 2.95 winamp
      not changed the memory
      it did work fine at the start or i didn't notice it till i started testing...
      i will try another skin
      thanks
      2005 STI :)
        any ideas?
        it freezing on my other system too! both epia
        1st one is 5000
        the other is the 1300
        same software on both!
        2005 STI :)
          Did you install flash?
          iGMon - Integration between iGuidance and Road Runner
          CFX - Skin for Road Runner
            Are you loading a super-large playlist? Mine sometimes freezes up for a few seconds if I'm loading several hundred tracks...
            '01
            Hang on while I defragment my car...
            the Acura ITX project
            the Acura ITX skin for RoadRunner
            project progress: 99%
              the only think i know of that will freeze RR 100% of the time is if you are trying to load an .exe file that is not present.
              beer replenishment fund
              mp3car live search
                I'm having this same problem ... any solutions yet? I've updated flash as explained in this FAQ http://www.mp3car.com/vbulletin/showthread.php?t=45529 but still no luck.
                  Is the CPU load high ? can you produce a debug file ?
                  Ride Runner RR's Myspace
                    Yeah the cpu goes up to about 92%. I decided its been far too long since I've done a fresh windows install so I'm in the process of doing that and setting everything up again. If I still have the problem after that I'll let you know. Thanks guino ... you're the COOLEST!
