RR (RoadRunner) and IBUS
  • RR (RoadRunner) and IBUS
    Hi CDrSkull and everyone else
    I have yet another problem with my setup.
    Computer Specs:
    epia M10000
    512 ram
    120GB HD 2.5"
    IBUS module (serial version) No USB
    Ibuscomm .ini file
    Latest Update of RoadRunner
    I had this running before, so i know it works. It doesn't work anymore becuase i reformated my computer After reloading windows XP and SP2, iBUS+RR does not work anymore. I'm not quiet sure if a driver is needed to have this module to work becuase i forgot what i did before problem is: whenever i run RoadRunner then ibuscomm (or vice versa) i get this "run time Error 13" message. WTF? now this is in my carputer setup.
    Going to my Laptop with the same RoadRunner + detects it and tells me no open commport. <--- that i understand because its not hooked up to my BMW. But as far as the carputer, the serial is working (tested it with ibus analyser). i just get that message
    What is going on?
    1. does my laptop have some drivers that my carputer does not have?
    That error happens when assigning data of a different/invalid type to a variable. Could be some weird setting like:
    In any case, doesn't sound like a missing file.. you said you ran the same RR+IBUSSCOMM, but I assume you used the same settings too ?
    Ride Runner RR's Myspace
      yes same settings, same files used as before... i cannot figure it out. Could it be the new version of RR?
      what's strange is that it works on my laptop, but not on the carputer.
      I don't know if it matters, but i tried winamp 2.95 AND winamp 5.0. Still no luck.
        where can i find old versions of Road Runner?
