RR 06-03-06 .. Few Improvements ..
  • RR 06-03-06 .. Few Improvements ..
    In this version:
    * Added Ireland to Mappoint's country list
    * Added support for hidden album art images
    * Added support to read any Setting as variable
    * Added option to Wait for USB sound card after hibernate
    * Added verification to only trigger skin buttons with left mouse click
    * Added label codes for displaying any audio line volume and winamp EQ values
    * Added Night Mode support to mappoint
    * Added changes by MatrixPC for Dual Monitor Support
    * Added commands to read from OSK/NUMOSK to Variable and INI
    * Added Radio Art Support
    * Added ONSKINEND event
    * Improved Gestures detection by adding a minimun drag distance
    * Improved BYVAR command to accept complex commands including ;
    * Improved organization of VoiceControl code by whodwho
    * Improved TIMER event to be re-occurring
    * Improved MPC control interface
    * Improved Radio playlist to work with current screen
    * Improved SAVETOINI when similar settings
    * Improved preload setting to prevent its use with menu.skin
    * Fixed issue with right and left list alignments
    * Fixed issue with RRConfig freezing on Win98
    * Fixed issue with wrong cover art switching between audio/video/skin browsers
    * Fixed issue with labels using multiple variables
    * Fixed issue with hidecontrols and hidemouse=true
    * Fixed issue with Built-in Video player Position
    * Fixed issue with CDRip not loading current skin on some machines
    * Fixed loading of Weather setting US/World in RRConfig
    * Fixed issues with album art browsing (really)
    * Fixed default screen limit in RRConfig (3 shouldn't be the default)
    * Fixed Centering issue with OSK when Y is not 0
    * Fixed SAVETOINI on empty variable
    * Fixed issue with height of scrolling labels (Thanks to fury)
    * Fixed issue executing multiple variable commands in sequence
    * Fixed issue executing multiple commands with ! (as repeat)
    * Allowed for spaces to be leading/trailing ID3 playlist format
    * Uploaded BrushAliminum PSDs
    * Helped EvolutionVIII with RadioShark Plugin (List & Slider support)
    Changes by Robby_BMW:
    * Improved PhoCo startup embedded in RR
    * Fixed issue with SKIPTO in SMSNUMBER.SKIN and SMSNUMBER1.SKIN
    * Added commands "CLOSE_PHOCO" and "RESUME_PHOCO"
    * Added support for contac's picture in "CONTACTDETAILS.SKIN"
    Mostly improvements and fixes, check the TXT files for reference.
    Thanks for your support as always,
    Guino.
    Ride Runner RR's Myspace
    sweet, thanks a lot, lots of good stuff in there.
    and im actually the first poster for once
    beer replenishment fund
    mp3car live search
      Downloading now. Thanks Guino. Keep up the good work.
      APPS:
      "RR CD Drive Monitor"
      Skins:
      Download the "MAS" beta here...
      New! The Skin Skin community project.
        im still getting some funkyness with the album art though
        im posting a screenshot so you can see what problem im having. Im not sure if the code is the same for viewing the album art outside of the album art browser. Browseing album art is fine, its the other album art i have issues with.
        In the screen shot, i have a button (mute) thats right on top of the album art, when you click it erases the album art and only shows again if you mouse over it.
        mp3car live search
          Figured you'd have to release a new version the day my AC adapter that I'm using to power my screen dies. Guess I should probably get to work on that to get it fixed so I can start playing with this version.
          Derek
          Progress [||-------]
          View my Worklog to see some of my progress.
          Downgraded Progress - Starting with another car... 09/13/06
            Yeah, I know that, in order to cut down on some resources I had to redesign the album art support, it can no longer be used on top of buttons. I'll think of something for that.. regardless of what I do, it only makes sense if the button is "invisible".
              Hey what is the Improved MPC control interface?
              Any bug fixes, added features or is the integration just a little better.
                just improved a bit on the integration.. had some issues when the skin was not at 0,0.
                  Grate work guino
                  ONSKINEND how does this work?
                  2001 S10 ZR2
                  Chucks Skin - to old
                    thats cool, i just wasnt aware if you knew i ment the albumart outside of the albumart browser since there were issues with that also. I have a temp fix though.
                    mp3car live search
                      Very cool. Just so happens I replaced/upgraded the PC yesterday. Thanks guino!
                      My Install Thread
                      digitaljetta.com
                      MKIV VW Jetta
                      How do I get sound to my car?
                        Confirmed that this works. Recommend for the next release, the default setting should be " %title". This would put a space between the playlist number and tracktitle.
                        Derek
                          Originally posted by Chuck
                          Grate work guino
                          Just an event on exectbl, opposed to ONSKINSTART..
                          "ONSKINSTART","<COMMANDAFTERSKINSTARTED>"
                          "ONSKINEND",""<COMMANDBEFORESKINCLOSES>"
                          It was a request by b8bboi, in any case, shutting down RR does not generate this event.. you should use the QUIT event instead..
                            GREAT Guino!
                            Thanks a thousand for that:
                            Guino, I didn't find the command. Looked in readme and skin commands... blind?
                            Oh, silly boy... It is just working perfect without do anything
                            Winni
