Problem compling rr with latest source code
  • Problem compling rr with latest source code
    I'm tryin to add some modifications to the phoco module and i'm having trouble compiling with microsoft visual basic 6.0 enterprise. No matter if i try to compile my modified project or the one downloaded directly from guino's site i get the same issue. Compiling inside of vb 6.0 gives me the following error:
    Compiling in the packaging wizard gives me this error:
    Compile Error: Cant Find Project or Library
    Compile Error in File 'C:\Documents and Settings\Shaun\Desktop\RoadRunnerSource\SubFolders .cls', Line 2 : Can't find project or library
    Build of 'rr.exe' failed.
    Also attached a pic of the section of code thats supposively causing the error. What gives?
    Live mp3Car Facebook Chat
    Sorry sonic,I can't code but i'm curious as to the nature of your mod?
    What are you changing??
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
      the Mid function is very basic within VB6 (seems to be your issue from the screenshot) .. I'm guessing one of the default libraries is shot on your install. Those are the references you need to make sure are in place before compiling RR (make sure you have microsoft scripting runtime checked):
      Ride Runner RR's Myspace
        yea the runtime is checked by default, as are all the other ones shown in your picture. I'll try reinstalling vb6 and hope that it goes away. If that doesnt work where else should i turn?
        Griff the only mod i'm doin is to add a button to disconnect the audio gateway thru rr. I need this as without it phoco is only usable as a standalone program. Have somethin else u need me to modify?
          You may want to try installing SP6 if you haven't done that yet.
            i got all the available updates and that got me past the mid function but i still have a problem in subfolders.cls. Same Error:
              that's part of the microsoft scripting runtime I told you about.
              Check that you have scrrun.dll, not blocked etc.
              SOMETIMES.. vb6 goes nuts and has issues with references, then you can try unchecking that reference, save/close the project & vb6, reopen it and re-check the reference and it starts working.
                The touchlist module some time drive me nut. I am sure I didn't change/mod anything on that module, and still give me error.
                save/close/reopen work just fine.
                Y2K Accord Dell GX150
                EmoRebellion is a SCAMMER
                  Yes i have a request please,I've been hoping for a change to the TEXT boxes in Phoco skins.
                  Currently they are not transparent ( but LISTS are ).Any Ideas?
                  Before going any further i should add that Guino considers this mod a lot of code.
                  Thanks for asking
                    ugh this is driving me MAD! I checked scrrun.dll, it exists. Its not in use and not blocked (as far as i can tell). I tried the method guino suggested and it still doesnt work. I replaced scrun.dll with another version from the net.... same error. Anything else anyone can think of? If push comes to shove i'll just use a different version of vb6.
                    Unfortunately griff i'm not that versed in VB to add that much code. The changes i'm making only require 2 lines of code. That makes it even more frustrating lol
                      No Problem Sonic,thanks anyway,good luck with your error mate.
                        you can try to regsvr32 the scrrun.dll file.. have you disabled any services in windows ? or disabled anything script-related ?
                          i registered the dll. Made no difference. I havent changed any of the services on this xp sp2 corp installation. Will try on my work pc tomorrow before just givin up.
                            Use Windows 2000 profesional.
                            I downgrade XP to win 2000 for work in VB6.0.
                            Sorry, i bad write english.
                              well it worked fine on my work computer thats running xp. I have no idea why it wont compile at home but i got it done here
