help for one fed up mancunian
  • help for one fed up mancunian
    HEEEEEEEEEELLLLLLLLPPPPPP
    i cant get music to play through rr when i click on music buttons. i set config to correct path for music on my hard drive, it find files but then wont play them (through winamp) am i doing something wrong - ive searched through forums all afternoon with no luck.
    what ive done/can do - reinstalled winamp into same folder as rr (would that matter so long as path is correct?)
    i can play music through winamp but not through rr
    do i need to load playlists etc into winamp - i tried but still no luck
    any advice for a noobie much appreciated - i can type and i can follow instructions, just sometimes not at the same time. i cannot knit and dont like hoovering up!
    winamp doesnt have to be in rrs folder you should leave it in program files as thats how its default in the config. Load a playlist into winamp, close winamp, then run rr. can you play ?
    Live mp3Car Facebook Chat
      what version of winamp are you using. Although the recommended version is 2.9 ive had success with newer versions up to 5.1, anything after 5.1 seems to bring a bunch of issues with just winamp itself and even more if used with RR.
      Is it a clean winamp install, may be a plugin acting weird. Generaly though, if you can hear music in winamp, RR shouldnt have any problems.
      beer replenishment fund
      mp3car live search
        thanks gents - i can play winamp as a standalone - when i stop winamp and launch rr itd when i get problems - im using lite version from downloads page,
        the pause button keeps flashing when i click on music but nothing happens?
        does this mean its reading the whole drive? any ideas as to why it should flash?
        i think a new install of rr is on the cards soon, just in case?
        dave bev
          i dont know about the lite version of winamp, i know some things are missing. Maybe try the fullversion.
          the pause button flashing (which skin) is prob just an idicator that your music is paused or muted.
          are you running the latest version of RR, not that it would matter, but always best to have latest fixes etc.
          mp3car live search
            went for a full reinstall of everything - five hours of forwards on step, backwards two! finally sorted, your posts helped because i could see there was no real reason it shouldnt work, so it had to be a software issue (methinks!!)
            again, thanks for your help
            dave bev
              when you say everything you dont mean windows do you? Just RR and winamp. Either way, its working now so go take a drive and listen to some tunes
              mp3car live search
                if only i could - i havent got to that stage yet, im still experimenting with the set up at home to make sure i dont have those problems on the road. not even installed in the car yet though i have the basics of a system, just putting one together as an experiment rather than spend a load of dosh on something i dont use
                dave bev
                  It will have been the lite version of Winamp, I'm sure I remember in the FAQs that the lite version doesn't work with RR.
                  Wish I'd seen this thread earlier, could have saved you quite some time.
                    actually the lite version is the one i have working? i uninstalled everything, then installed the lite version, then installed rr and subsequent web updates and everything seems ok so far!
                      So the big Q is= Why is the lite version on the RR downloads site?
                      It might be an idea to replace it if it don't work in RR.
                      P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
                        it does work! at least it does for me anyway!
                        dave bev
                          Well i don't know what to think really,Guino's FAQ says don't use it but the site hosts it,and i'm forever reading "don't use a lite version" but people report that it works. To be safe i don't use it.
                            The winamp in rrdownloads is the FULL 2.95 version. The LITE version is a stripped out version of winamp which lacks many features, there are lite versions as early as 2.x and as late as 5.x .. Most of them work to some extent, but then we get people complaining that this or that feature in RR doesn't work -- because winamp isn't acting propperly.
                            Ride Runner RR's Myspace
