Alpine skin Xm quesiton
  • Alpine skin Xm quesiton
    Has anyone been able to get the XM signal sliders working?
    I switched back to BMV skin and all works, but as soon as i use Alping Green S it does not work.. otherwise its a great skin!
    I have all the sub folders with pointer and gif files in correct dirs..
    thanks!
    -Jack
    2006 Chrysler 300C AWD
    Samsung Galaxy Tab In dash
    if all files are there, you probably have something wrong in xm.skin
    Ride Runner RR's Myspace
      thats what im thinking.. i went through and compared the xm skin files and they look completley different.. i dont see any sliders defined for the signal bars.. i added them from the bmv skin to see if i could get it but no can do.
      does anyone have a working Alpine Skin xm.skin that shows the signal strength?
      Guino can you see if there is anything wrong.. i added S02 and S03 of the slider function. There was no other reference to the XMSAT or XMTER
      the gif files are in the Slider4 dolfer under the alpine skin directory..
      c:\program files\roadrunner\skins\alpine-s\slider4
      /, (S) Slider
      /, X Y W H X1 Y1 W1 H1 O STYLE POINTER H2 CODE TOOLTIP
      S01,463,282,276,033,490,224,293,030,H,01,"SLIDER3\ POINTER.gif",013,"songpos",""
      S02,523,448,037,020,163,255,163,018,H,01,"SLIDER4\ POINTER.gif",015,"XMSAT",""
      S03,628,448,037,020,163,255,163,018,H,01,"SLIDER4\ POINTER.gif",015,"XMTER",""
      END
      thanks for any help!
      -Jack
        Where are the Y definitions that are supposed to go with that ?
          Ok i knew i forgot something.. i dont see a Y setting..
          I added it and it worked.
          I will PM More mods to update his XM.skin
          You need to add:
          Y01,"SLIDER4\slider_*.gif"
          and you need to remove
          L08,523,448,037,020,163,255,163,18,"LCD Display Grid","XMSAT",
          L10,628,448,037,020,163,255,163,18,"LCD Display Grid","XMTER",
          Works like a charm..
          Thanks guino
          -Jack
