Latest Flash causing lots of Flash Skins to break
  • Latest Flash causing lots of Flash Skins to break
    The latest flash v9.0.16.0 from Adobe is causing lots of flash based skin to stop working. I have tested MC2.0, XEON and RAD and all stopped working.
    Good thing I still have a copy of the previous flash v8.0.24.
    Good to hear. Thanks for the report.
    1.9in x 2.9in -- 47mm x 73mm
      Could you post it please?
      iGMon - Integration between iGuidance and Road Runner
      CFX - Skin for Road Runner
        maybe I need to compile RR with Flash 9, then it should work well.. I'll test tomorrow.
        Ride Runner RR's Myspace
          guino, it's not just RR. I tried to open Tissy's clock in IE, for example, and it didn't work there either.
            great.. so Macromedia F'd things up big time..
            EDIT: Ahhh it's now ADOBE flash player.. gotta trust Adobe to screw things up like they did with their PDF reader ..
              In case you upgraded to Adobe Flash 9.0 and do not have a restore point in WinXP.
              How to uninstall the Adobe Flash Player plug-in and ActiveX control
              http://www.adobe.com/cfusion/knowled...fm?id=tn_14157
              Archived Macromedia Flash Players available for testing purposes
              http://www.adobe.com/cfusion/knowled...fm?id=tn_14266
                Thx MycoDex, but installing flash 8 didn't work with RR - RR freezes on startup with flash 8 r.22 or r.24!
                  Thanks MycoDex. Worked for me.
                    Did it work before?
                      I've done some testing this morning and updated the FAQ install procedure, if you've already installed 9, you may want to try followint the updated FAQ.
