Winamp Vis background
  • Winamp Vis background
    Is possible, when i click the VIS button, to load a background image (on OFF, ON and DOWN layers) and, clicking again the VIS button, unload it???
    i want add borders to winamp visualization...
    the firts image I attached is the main menu, the second is the menu with visualization border...
    is it possible???
    ah, in the center of the screen there is a flash clock... when i click the VIS button, the visualization hides clock. is it possible to unload swf clicking vis button (for performance reasons) and reload it clicking again???
      it's not possible to unload the flash object, but with the new release it will be possible to hide it (check latest beta files).
      You can use the LOADIMG command along with the VIS command to load the correct image on the background before/after showing the vis.
      Ride Runner RR's Myspace
        when can i program a button to do this???
          you can use the same vis button you use to turn it on/off.
            how can I do to add more than one function in a single button?
            like VIS and LOADIMG clicking a single button.
            someone could help me?
              Just add a line like this in your ExecTBL.ini file
              "VIS","LOADIMG COMMAND|VIS"
              You just have to use the pipe "|" inbetween commands to perform multiple command from one button
              Next in line: RRMedia v2.0
              DFX 5.1.1 Skin
              Appstore Link
              My RideRunner Plugins
              RRMedia
              RRExtended
              DFXVoice
                ok... thanks... if I want to create a toggle button...???
                how can I do?
                  I think with that you would need to set up a varible or something...I'm just not sure and don't want to give info on something I don't know off the top of my head..
                  Chuck would def know right off his head, his skin(s) have mile long button commands.
                  DFX 5.1.1 Skin
                  Appstore Link
                  RRMedia
                  RRExtended
                  DFXVoice
                    uhmmm, good idea...
                      Ok,
                      If I understand this correctly, I think the command you want is this (Extract from skin commands.txt)
                      "SETVAR" - This allows you to set a global variable in RR. Those variables can be used for simple
                      reference in the skin commands
                      or be used to toggle between different groups of commands on skins (using BYVAR command).
                      Example: "SETVAR;APPPATH;C:\MyApp\Myapp.exe"
                      Then you can reference the variable APPPATH like this: "RUN;$APPPATH$"
                      In your case the syntax would go something like. . .
                      B02,666,3,132,85,"LOADIMG;100;100;200;200;Menu.gif ;OUT||SETVAR;SwapImage;1||SWITCHBUTTON;2>>LOADIMG; 100;100;200;200;Media.gif;OUT||SETVAR;SwapImage;0| |SWITCHBUTTON;2",""
                      I'll try and explain what it does, Chuck helped me out with this syntax a while back.
                      B02,666,3,132,85,"LOADIMG;100;100;200;200;Image1.g if;OUT||
                      The first part defines your button, and makes button 2 execute your Load image command.
                      SETVAR;SwapImage;1|| This bit sets a Global Variable I have called SwapImage with the 1st command, and then you need to switch the button command to the second condition with
                      SWITCHBUTTON;2>>LOADIMG;100;100;200;200;Image2.gif ;OUT||
                      the 2 after switch button is the second button in sequence, if you have defined this as the tenth button, change it to 10 ! The button will now load Image2.gif when pressed.
                      SETVAR;SwapImage;0|| This then allows the global variable to be toggled to the second condition which is defined as
                      SWITCHBUTTON;2","" and when the button is pressed executes the first defined command to Load Image1.gif.
                      I hope that helps (and works lol)
                      cheers KPJUK
                      M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
                      DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
                        Oops !
                        Double post
                          Nice write up...
                          DFX 5.1.1 Skin
                          Appstore Link
                          RRMedia
                          RRExtended
                          DFXVoice
                            Thanks,
                            I hope I got it right ! lol
                            KPJUK
                              WOW.. what skin is that? Is this available?
                              share plz..
