How to show "3GP File" in videobrowser
  • How to show "3GP File" in videobrowser
    I put ",.3GP" in video file types in rr config but it don't work.
    can you play these files in mediaplayerclasic outside of RR?
    when you add the file type inside of RR that just tell RR to show you that file in the browser, you still need a codec for it to actually be viewable.
    beer replenishment fund
    mp3car live search
      the only media player that plays the .3gp files(which is a cell phone format i beleive) is real player. if you want to use windows media for example youll need to find a codec.
      MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
      M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
      7" Lilliput 619 | WinTV | WIFI | Bluetooth
      Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
      Roadrunner | LSXvoid | IGuidance 3
      My Worklog
        search for 'real alternative' and you'll find the codec you need to play real media -- not sure it will play those new formats though.
        Ride Runner RR's Myspace
          I can play ".3GP" outside RR with mediaplayerclassic. but can't play in RR.
            well, I can't possibly make a built-in player that plays everything.. if it works in MPC, then turn off the built-in player option and use MPC to play it in RR. The Built-in player will play anything that WINDOWS is able to handle natively -- even if by using codecs (I have many .RAM files in the car, which require real audio codecs installed, and they play in the built in player fine)
              Hi Guino,
              i'm picking up this little older thread because I ran into similar problems.
              I'm trying to playback .swf, .mov and .rm files. The play fine if opened with MediaplayerClassic, they play fine if double clicked (that means windows CAN handle them, doesn't it?) (Quicktime and Realpalyer are installed)
              With the built in player i only get a black picture.
              If I uncheck the built-in player they will play fine, but some of my commands won't work anymore. (i.e I've created a double function for the FastForward Key on my remote, short press jumps to next song/video, long press fastforwards through the actual track)
              So I would like to use the builtin player. What's the exact criteria that you mean by "windows must be able to handle the files natively"?
              Thanks in advance
              JarJar
              My System: Via Epia MII 10000, 1GB RAM, 80GB 2.5HDD, Slimline DVD Writer, Roadrunner
              My CarPC Project:http://www.stromgmbh.de/carpc/index.htm
