Bass/Treble controls next to Master Volume
  • Bass/Treble controls next to Master Volume
    What control are those tied to? They seem to randomly reset all the way back down to the bottom. I find I have to put them back to where I like them all the time and I can't find how to make my selection permanent.
    Thanks.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    go into rrconfig and change the setting to control the master volume only.
    MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
    M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
    7" Lilliput 619 | WinTV | WIFI | Bluetooth
    Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
    Roadrunner | LSXvoid | IGuidance 3
    My Worklog
      The BASS & TREBLE sliders in the mixer ONLY WORK with soundcards that support the BASS & TREBLE advanced controls -- you can check that in your windows mixer, if it lets you change the BASS/TREBLE then they should also work in RR. If not, the controls in RR won't do anything.
      Ride Runner RR's Myspace
        it doesnt sound like he has a problem since he says he sets them.. he just wants the bass and trebel to hold when he sets it instead of going back to 0. i think. lol..
        anyhow i just got a chance to look at rrconfig. change the option under music tab:
        Map Master Volume to Control Line (For Weaker Soundcards):
        from All Lines to Master Volume
        My Worklog
          Thanks guys. I'll give those a try.
            Is it possible to chance the Bass/Treble to Front/Bass
            In my Soundoptions, i can fade the Front, Rear, Center and Bass Options.
            In the RoadRunnerSkinEditor i didn´t found these options.
              It depends on what skin you are using if they are acailable. Some skins simply have the equalizer settings, and some have all of the functions.
              As for the skin editor, The treble and bass are under "Sliders"(S) and are labled "BASS" & "TREBLE" respectivly.
              Currently I see no "fading" options. You will have to set the fader with your Sound Cards Drivers, or control it with your radio/head unit.
              My Fiero Build Thread
                I´m sorry. Withe "fade" I meant changing the Volume of "Front", "Rear", "Center" and "Bass" ... not fading to the Left oder to the right.
                I´m using "ZdGrey.day" and testing XEON, Freedom and Flashdesk.
                Maybe I should test it and replace the Option "Bass/Treble" with "Front/Bass" in the RoadRunner Skin Editor ?
                  Yes, I understood the fade as being from front to rear. Ballance is left to right. I am not aware of a fade command in RR. I have my RR audio going into my head unit, and control ballance, fader, bass, treble ect from there.
