Nck 5
  • Nck 5
    Another Noob´s Question,
    i searched in this Forum, but found nothing, that help me. Sorry if it is not so!!
    I have the new NCK 5, for Info´s from where, contact me per PM!!!
    Now the question:
    It runs 100% embedded. But the music will not muted, when NCK say something.
    How can I make RR to make this?? Has anybody an solution for me??
    Thank you all,
    LogDoc
    i too have nck 5 can post the steps which did to embed it 100%
      Cool,
      can you post it please. The other thing is, did you manage it to mute, when directions said??
      Thank you
        Pics would be nice for the rest of us
        Terran
        PS I thought NCK6 was the new one ?
        My Project Site
          Wouldn't mind seeing the instructions to embed with RR if anyone has a quick guide!
          Cheers
            unless it has some sort of SDK/API available for integration, it will not be possible to lower the volume when directions are spoken. (unless of course, the software can do it by itself).
            Ride Runner RR's Myspace
              Here's a screenshot of NCK5 in action
              2+2=Quattro
              Audi S6 2.2 Turbo
              RNS-E Headunit
              Helix HX400=AXTON Amp
              Audi Doorspeakers and 15" JBL in Sparewheel Hole
              19" Alutec Alloys, ABT-Silencer, FK-Suspension
                dbassix: Looks very nice - How did you handle the problem of no OSK, does the RR OSK type addresses without problem or does it require tweaking ?
                Also noticed an option in NCK5 for 'Radio Mute' not sure how that function works - but if we can lower Winamp volume on voice guidance then it looks like this would be a perfect carpc sat nav!
                  The RR OSK is working perfect for this. Also MouseWheelInput is working. NCK lowers the wave volume when saying directions. U can set this in the Options dialog.
                  2+2=Quattro
                  Audi S6 2.2 Turbo
                  RNS-E Headunit
                    Thanks for the info dbassix!
                    Great stuff, just had a play with some of the settings and it looks very nice - one minor thing, does anyone know an INI command to stop the "Warning do not use when driving" when starting NCK5 ?
                    I've had a look through the manual but can't see a command for it..
                      Thats nice... worth looking at if TMC in the Uk is covered ( there where licencing issues here ).
                      Terran
                      My Project Site
                        put this line into your prefs.ini:
                        [NCK]
                        showsecuhint = 0
                        2+2=Quattro
                        Audi S6 2.2 Turbo
                        RNS-E Headunit
                          Ok, having played around with NCK5 it looks quite smart - A worthy replacement for IGuidance
                          The only thing still to sort is getting rid of the annoying warning screen at the start, but thats not so bad!
                          As for muting music when guidance is on - I noticed the winamp volume simply matches the guidance volume, so I created a small program to monitor NCK5 and when guidance is speaking it will lower Winamp's volume to 65, once finished it raises back up to 255.
                          I've attached my program - which is unsupported at the moment so you'll have to suck it and see
                          As long as you put the program into RR's root folder (where EXEC lives) and you have the Navigon voice volume set to 90% and your WAVE volume above 90% then it should work fine.
                          You will also need the .Net framework installed..
                          -= EDIT =-
                          Just noticed your post on removing the warning dbassix, Top Stuff!!!
                            Hi, can I answer what is the Skin name? thx.
                              Hi @ all,
                              now it is online again. So hurry and download it. More infos @
                              <LINK REMOVED> (Sorry, No warez allowed on this site)
                              Look there at posting Nr. 10!!
                              But you have to register to read the thread.
                              And please, push there the Thank Button.
                              Have fun
