Music initially loud then normal
  • Music initially loud then normal
    How come when I start Music or change to the next mp3 track in RR the audio starts off really loud for an instance then drops back down to the volume level I have it at? I'm using Winamp 2.95.
    Sounds like you have some normalization plugin installed. There's no such feature built-in into RR.
    Ride Runner RR's Myspace
      I just installed the winamp295 package on rrdownloads.net and I'm using LSX Void skin. I didn't tinker with the winamp install.
        There was nothing documented on it, but i noticed my audio amps did this.
        Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
          This doesn't happen for me in Mediaengine and I believe that is winamp-based also.
            The deal is that other FEs based on winamp normally ship winamp preconfigured with it. I'd suggest you take a look at your winamp's plugin settings. or even, just play with it OUTSIDE RR to see if the same happens -- if it does, it's not RR, if it doesn't then I'd like you to make a debug log in RR.
              Ok, thanks. I'll check it out
                Ok so I think I figured it out. The initial loud volume was occurring in Winamp outside of RR so it isn't a RR problem. In the Input plugin menu, wave_out was one of the 2 plugins installed (by default I assume because I never installed it). In the options, Volume Control Enabled was checked. When I unchecked it, the volume was working fine and it worked fine in RR. Thanks for the tip about checking the plugins.
