command "DIRECTION" & Map Monkey
  • command "DIRECTION" & Map Monkey
    Hi.
    I have the small problem....
    Is it possible to see the images "direction" using "Map Monkey" like "freedrive" in the "Road Runner" program?
    Will you please help me ?
    Thany you!
    the "DIRECTION" >indicator code< should work for both MM and FD. But you must have them propperly configured for that to happen -- for MM you have to use Advanced Mode with a NMEA GPS with the TCP integration in place -- check the FAQ. For FD, you have to tell it to send all data to RR (in it's INI).
    Ride Runner RR's Myspace
      thank GUINO,
      sorry...but i don't unterstand....
      In MM i have set "Advanced Mode with a NMEA GPS" but where is the "TCP" setting?
      Is possible to write me the link for this problem..?
      thank guino
      sorry for my english!!
        Read the Map Monkey Section of this FAQ:
        http://www.mp3car.com/vbulletin/showthread.php?t=45536
