Label with word wrap
  • Label with word wrap
    Guino would it be easy and possible to make a label with word wrap option for tall labels?
    L69,289,211,400,500,224,223,227,10,"Arial:B","=$TE XTHELP$","word wrap"
    2001 S10 ZR2
    Chucks Skin - to old
    Guino -
    Actually my PM as well as what Chuck mentions are kinda the needs. Both would be wonderful but know you are constrained sir. Just wanted to mention that this one as well as the MovieText params would be fantastic.
    Just let us know sir.
    Thx
      Chuck, I've added a wrap option for next release, but the "Scroll-up" option is the only current option that wraps the text.
      Ride Runner RR's Myspace
        Thx guino
        I guess I should have explained myself a little better
        I meant a label with multiple lines with word wrap
        2001 S10 ZR2
          Hey Chuck,
          a quick off topic . . . . Have you got any examples of a button swapping between 3 options. I want to create a menu button that when you press it, changes the button defs on the other 7 buttons. I can get it to work for 2 sets of options, but not for 3 !
          what I mean is
          b1 b2 b3 b4 b5 b6 b7 menu
          When the skin loads up b1 = PREVIOUSTRACK
          Press menu and b1 changes to GPS
          press menu again and b1 changes to GAMMA
          press it again and b1 goes back to PREVIOUSTRACK
          I am trying to get the whole skin managed by a single row of buttons, like my Alpine head unit. Any examples you got would be great.
          cheers master guru
          KPJUK
          M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
          DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
            PHP Code:
            Single button to change the command for itself
            “BYVAR
            ;SETB1;PREV<<GPS<<GAMMA||BYVAR;SETB1;SETVAR;SETB1;1<<SETVAR;SETB1;2<<;SETVAR;SETB1;0”
            Separate button to change command to anther button
            Set button
            “BYVAR
            command button
            “BYVAR
            ;SETB1;PREV<<GPS<<GAMMA”
            And if you want a text label for that button
            “BYVAR
            ;SETB1;Prev<<GPS<<Gamma”,"CENTER"
            2001 S10 ZR2
              Also if you want it to save so when you restart RR
              PHP Code:
              “BYVAR;SETB1;SETVAR;SETB1;1<<SETVAR;SETB1;2<<;SETVAR;SETB1;0||SAVETOINI;SETB1;$SETB1$”
              2001 S10 ZR2
                Thanks Chuck,
                I knew you were the man to help out, apologies for hi-jacking your thread !
                I will give this a bat and see if I can get it going. I'll let you know
                Cheers Bud,
                KPJUK
                  Nice 1 mate,
                  I'm using the LOADIMG command to load small gif's for the Button "labels", and this is now working a treat, I just need to do the switchbuttons now and I'm sorted.
                  For reference for anyone else trying this, here is method used.
                  Button command set up in skin
                  /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
                  B01,3,0,99,66,"PREVTRACK","CENTER"
                  B02,101,-2,101,68,"FRWD","CENTER"
                  B03,199,-2,102,68,"PLAY","CENTER"
                  B04,300,-2,101,68,"STOP","CENTER"
                  B05,399,-2,102,68,"FFWD","CENTER"
                  B06,500,-2,103,68,"NEXTTRACK","CENTER"
                  B07,601,0,98,66,"OSK",""
                  B08,701,0,98,66,"MNUSwap",""
                  B99,687,548,114,49,"EXIT",Center
                  Button 8 is a custom command that is defined in Exectbl.ini as follows.
                  /, MenuSwap Commands
                  "M2B1","LOADIMG;14;8;75;50;M3-B1.gif;Out||LOADIMG;14;8;75;50;M3-B1.gif;Off||LOADIMG;14;8;75;50;M3-B1d.gif;Down||LOADIMG;14;8;75;50;M3-B1d.gif;On"
                  "M2B2","LOADIMG;114;8;75;50;M3-B2.gif;Out||LOADIMG;114;8;75;50;M3-B2.gif;Off||LOADIMG;114;8;75;50;M3-B2d.gif;Down||LOADIMG;114;8;75;50;M3-B2d.gif;On"
                  "M2B3","LOADIMG;214;8;75;50;M3-B3.gif;Out||LOADIMG;214;8;75;50;M3-B3.gif;Off||LOADIMG;214;8;75;50;M3-B3d.gif;Down||LOADIMG;214;8;75;50;M3-B3d.gif;On"
                  "M2B4","LOADIMG;314;8;75;50;M3-B4.gif;Out||LOADIMG;314;8;75;50;M3-B4.gif;Off||LOADIMG;314;8;75;50;M3-B4d.gif;Down||LOADIMG;314;8;75;50;M3-B4d.gif;On"
                  "M2B5","LOADIMG;414;8;75;50;M3-B5.gif;Out||LOADIMG;414;8;75;50;M3-B5.gif;Off||LOADIMG;414;8;75;50;M3-B5d.gif;Down||LOADIMG;414;8;75;50;M3-B5d.gif;On"
                  "M2B6","LOADIMG;514;8;75;50;M3-B6.gif;Out||LOADIMG;514;8;75;50;M3-B6.gif;Off||LOADIMG;514;8;75;50;M3-B6d.gif;Down||LOADIMG;514;8;75;50;M3-B6d.gif;On
                  "M2B8","LOADIMG;714;8;75;50;M3-B8.gif;Out||LOADIMG;714;8;75;50;M3-B8.gif;Off||LOADIMG;714;8;75;50;M3-B8d.gif;Down||LOADIMG;714;8;75;50;M3-B8d.gif;On"
                  "M1B1","LOADIMG;14;8;75;50;M2-B1.gif;Out||LOADIMG;14;8;75;50;M2-B1.gif;Off||LOADIMG;14;8;75;50;M2-B1d.gif;Down||LOADIMG;14;8;75;50;M2-B1d.gif;On"
                  "M1B2","LOADIMG;114;8;75;50;M2-B2.gif;Out||LOADIMG;114;8;75;50;M2-B2.gif;Off||LOADIMG;114;8;75;50;M2-B2d.gif;Down||LOADIMG;114;8;75;50;M2-B2d.gif;On"
                  "M1B3","LOADIMG;214;8;75;50;M2-B3.gif;Out||LOADIMG;214;8;75;50;M2-B3.gif;Off||LOADIMG;214;8;75;50;M2-B3d.gif;Down||LOADIMG;214;8;75;50;M2-B3d.gif;On"
                  "M1B4","LOADIMG;314;8;75;50;M2-B4.gif;Out||LOADIMG;314;8;75;50;M2-B4.gif;Off||LOADIMG;314;8;75;50;M2-B4d.gif;Down||LOADIMG;314;8;75;50;M2-B4d.gif;On"
                  "M1B5","LOADIMG;414;8;75;50;M2-B5.gif;Out||LOADIMG;414;8;75;50;M2-B5.gif;Off||LOADIMG;414;8;75;50;M2-B5d.gif;Down||LOADIMG;414;8;75;50;M2-B5d.gif;On"
                  "M1B6","LOADIMG;514;8;75;50;M2-B6.gif;Out||LOADIMG;514;8;75;50;M2-B6.gif;Off||LOADIMG;514;8;75;50;M2-B6d.gif;Down||LOADIMG;514;8;75;50;M2-B6d.gif;On"
                  "M1B8","LOADIMG;714;8;75;50;M2-B8.gif;Out||LOADIMG;714;8;75;50;M2-B8.gif;Off||LOADIMG;714;8;75;50;M2-B8d.gif;Down||LOADIMG;714;8;75;50;M2-B8d.gif;On"
                  "M0B1","LOADIMG;14;8;75;50;M1-B1.gif;Out||LOADIMG;14;8;75;50;M1-B1.gif;Off||LOADIMG;14;8;75;50;M1-B1d.gif;Down||LOADIMG;14;8;75;50;M1-B1d.gif;On"
                  "M0B2","LOADIMG;114;8;75;50;M1-B2.gif;Out||LOADIMG;114;8;75;50;M1-B2.gif;Off||LOADIMG;114;8;75;50;M1-B2d.gif;Down||LOADIMG;114;8;75;50;M1-B2d.gif;On"
                  "M0B3","LOADIMG;214;8;75;50;M1-B3.gif;Out||LOADIMG;214;8;75;50;M1-B3.gif;Off||LOADIMG;214;8;75;50;M1-B3d.gif;Down||LOADIMG;214;8;75;50;M1-B3d.gif;On"
                  "M0B4","LOADIMG;314;8;75;50;M1-B4.gif;Out||LOADIMG;314;8;75;50;M1-B4.gif;Off||LOADIMG;314;8;75;50;M1-B4d.gif;Down||LOADIMG;314;8;75;50;M1-B4d.gif;On"
                  "M0B5","LOADIMG;414;8;75;50;M1-B5.gif;Out||LOADIMG;414;8;75;50;M1-B5.gif;Off||LOADIMG;414;8;75;50;M1-B5d.gif;Down||LOADIMG;414;8;75;50;M1-B5d.gif;On"
                  "M0B6","LOADIMG;514;8;75;50;M1-B6.gif;Out||LOADIMG;514;8;75;50;M1-B6.gif;Off||LOADIMG;514;8;75;50;M1-B6d.gif;Down||LOADIMG;514;8;75;50;M1-B6d.gif;On"
                  "M0B8","LOADIMG;714;8;75;50;M1-B8.gif;Out||LOADIMG;714;8;75;50;M1-B8.gif;Off||LOADIMG;714;8;75;50;M1-B8d.gif;Down||LOADIMG;714;8;75;50;M1-B8d.gif;On"
                  "MNUSwap",“BYVAR;MenuSwap;MNU0<<MNU1<<MNU2||BYVAR; MenuSwap;SETVAR;MenuSwap;1<<SETVAR;MenuSwap;2<<SET VAR;MenuSwap;0”
                  "MNU2","M2B1||M2B1||M2B2||M2B3||M2B4||M2B5||M2B6|| M2B8||SETVAR;MenuSwap;0"
                  "MNU1","M1B1||M1B1||M1B2||M1B3||M1B4||M1B5||M1B6|| M1B8||SETVAR;MenuSwap;2"
                  "MNU0","M0B1||M0B1||M0B2||M0B3||M0B4||M0B5||M0B6|| M0B8||SETVAR;MenuSwap;1"
                  MNUSwap in turn runs three other custom commands. I set it up this way to be able to debug it easier.
                  These custom commands loadimages on top of each other, for each of the buttons, then resets the variable for the next time around.
                  I'll edit this post when I get the switchbuttons working !
                  Thanks again m8
                  KPJUK
