Plugin crashes RR!
  • Plugin crashes RR!
    Hi everyone!
    I'm having some problems with a plugin, I'm posting here hoping that someone might know what's wrong...
    Not that it matters but it's the milage one from the plugin forum, but I was hoping that someone else might have had the same problem with some other addon and know what to do...
    I've done everything the way I should, registered the dll file, add the x,pluginname to the skin file and so on but everytime I try and go to the skin with it RR freezes on me...
    Posting the part from the debug file;
    Code:
    2006-09-16 17:05:10: Que Exec: True, menu.skin, "LOAD;tripmeter.skin", False
    2006-09-16 17:05:10: Executing: LOAD;tripmeter.skin
    2006-09-16 17:05:11: Leave Exec: False, menu.skin, LOAD;tripmeter.skin, False
    2006-09-16 17:05:11: SDK command: REQUEST;milage;RRPATH
    I tried another plugin just to see if it was my config or something but that worked ok...
    The only part that I didn't see in that file was the SDK command above...
    Is there some SDK I need to install or something?
    Thanks for any answers...
    Swedish site for CarPC's
    http://www.bilpc.info
    Do you have any windows/folders opened with the name "milage" in them ? if so, try renaming/closing those windows.. at first, that seems a bit of a poor choice for the plugin's name (not your fault though). Anyway, be sure you've added the x,pluginname to menu.skin >ONLY<.
    Ride Runner RR's Myspace
