lil help with iguidance 3
  • lil help with iguidance 3
    ok i finally got iguidance and my gps receiver and everything works good but when i open up iguidance in roadrunner i cant switch back without closing out of iguidance causing me to lose the route when i restart. Now i figure this is something easy and i have been searching but i cant seem to figure it out. ive downloaded a few different things for RR that i thought would fix it but they havent. Could someone please point me in the right direction? Thanks a lot!!!
    Fisher Customs
    www.fishercustoms.com
    AMD mobile Athlon 3200+, 512mb ram, M2-ATX, 8" dynamix 16:9, powermate, 80 gig hd, 802.11G PCI w/ stubby antenna, SB Live Soundcard, hardwired into stock Bose system
    What skin are you using? You may want to check the .skin file to see if it is closing iguidance or loading the menu screen.
    It should look something like this:
    Code:
    B03,676,1,122,54,"LOAD;MENU.skin",
    Obviously it should hace the proper coordinates and such. You can use rrskineditor to make it easier if you aren't familiar with the skin code.
    Yeah google!
      im using the Alpine skin but when i open up iguidance it covers up the close and exit buttons on the top. when i close iguidance it goes to the menu at the top but nothing else and i have to exit that to get back to the main menu. I'm not too sure what u mean by the .skin file but ill check it out. If you have any other ideas lemme know. Thanks
      Fisher Customs
        What have you downloaded in order to fix the problem.
        I think the problem is that IG is not embedding into RR. How to start IG? What do you press on the skin. What are your GPS settings in RR Config. All of them?
        Michael
          ok yeah i think thats my problem. all i did was go into RR config and have the gps point towards iguidance. then i just push on the gps button on the main menu or in the music the little gps button. how do you embed IG into RR. sorry ive searched and cant figure it out...
          Fisher Customs
            Check the FAQ section in the RR forum. If should be there.
            Michael
              so am i just looking for how to embed iguidance. or is there something else im supposed to do?
              Fisher Customs
                http://www.mp3car.com/vbulletin/showthread.php?t=45536
                Michael
                  ok i did that first part now im onto this part.....
                  Other GPS Applications (i.e. FreeDrive)
                  -Set the External GPS path to your applications path
                  -Set the GPS Window Name to your GPS Window name
                  If your GPS application needs specific parameters, you should add a " " (including quotes) after the application's path. For Example (for External GPS Path setting):
                  C:\MyGPS\MyGPS.EXE" "Param1 -Param2 Param3
                  You can look at THIS FAQ to find the GPS Windown Name for your GPS application.
                  For example, for FreeDrive you should enter "FreeDrive" (no quotes on the GPS Window Name)
                  I must be a complete idiot because i cannot figure out how to do this. anyone care to break it down for me? where do i put in the window name? all i want to be able to do is switch back and fourth between roadrunner and IG without having to shutdown IG and loosing my route.
                  Fisher Customs
                    Setup GPS application to be use with RoadRunner. (iGuidance for example).
                    Look at RR.ini file
                    gpsmode=2
                    gpspath=C:\Program Files\iNav\iGuidance\iGuidance.exe
                    gpsname=Iguidance
                    With the latest release of RoadRunner, you don't have to pass the "nowarning" parameter to suppress the warning window. Also,you have an option to run iGuidance in native mode or just embedded mode by setting
                    ignative=true/false
                    in rr.ini. The advantage and disadvantage among the 2 is in the "iGuidance native in RoadRunner" thread. Look it up.
                    Now double check the skin file namely (external_gps.skin) to see what command does the Exit/Close/Return button is execute. You can use "CLOSE" command to close the screen without shutdown iG to return back to the main menu. In main menu or where ever, if you execute "GPS" command again, GPS screen will be reload.
                    All RoadRunner setting can be found in readme.txt.
                    All Roadrunner skin command, label, .... are in skin command.txt
                    Y2K Accord Dell GX150
                    EmoRebellion is a SCAMMER
                      i added the ignative=true line to my rr.ini, but no change. Do i need a special skin?
                      -Ross
                      02 Camaro SS
                      Opus 150W($150 used) Morex Venus 668 Case($109) Epia M10k($166) 128 Megs ($0), Maxtor 200Gig($76) CD-R/DVD($29) Lilliput 7"($285) Buffalo Airstation($42) Holux GPS($53) GM10-AUX(audio input, $72)
                      Tot: $983
                      Buying stereo!
                        I was having the same problem as you. I fixed it by changing the gpsname to exactly what matrixpc said to change it to. That would be Iguidance. Now it works correctly. Just follow the laid out instructions and your hsould get it to work.
                        Computer:
                        COMPLETE SYSTEM OVERHAUL!!!!!!
                        STAY TUNED IN THE UPCOMING WEEKS!
                          I was having this same problem also. What finally resolved it for me was removing the C01,000,055,800,545 line from my external_gps.skin file. After that, everything worked fine.
                            ok sorry to jack this thread. i have a problem! i have iguidance setup and when i run the program standalone it works great. i have my gps set to com 5 baud at 4800. now i go into RR and configure my gps settings. same thing com 5 gps external and the directory is set to where iguidance is and iguidance is set as window name. now i load up RR and click on gps, iguidance starts then it gives me "please make sure your gps reciever is connected" i exit out of RR and load up just IG, it works, i go to my gpsinfo and its working. i go back to RR and it doesnt work. when im in RR i see iguidance on the screen so it loads up fine it just doesnt detect the gps reciever.
                            any help will be great
                              You need to install XPORT3. In order for Raod Runner and IG to work correctly you need to split the com port. You need one for RR and one for IG.
                              Set XPort3 to you com port where the receiver is plug in then select Enable and split the port to 6 and 7. Use 6 for RR and 7 for IG.
