Interesting problem with iGuidance
  • Interesting problem with iGuidance
    Okey i have iguidance working in my carputer but i have a weird thing happening......if i run ig outside of rr it detects the gps antenna with no problem....and works well...however when i launch ig from inside rr (embedded) it does not detect the gps antenna !@#$^&*() any ideas ???
    http://www.sounddomain.com/ride/856246
    Please visit my new site http://www.Gigabitcustoms.com
    My worklog http://www.mp3car.com/vbulletin/showthread.php?t=52720
    do you have the gps com port in RR set to the same com port as IG ?
    beer replenishment fund
    mp3car live search
      Yes...both are set to com 3...still does not work
        You need to change it to something else. iGuidance will manage the com port on it's own.
          thats the problem, that they are both set to the same com port.
          AFAIK IG will not manage a com port on its own, you have to set it or scan for it, but once you do it once, it will remember.
          What you need to do is either disable the com port in RRConfig, set it to zero
          OR, do a search for xport which is a com port splitter. Xport will allow you to have multiple applications connect to the same gps device, by default gps devices only allow one connection to its port at a time.
          When you split the com port you can then create virtual comports that have different numbers but all contain the same data. So you can RR, IG and other gps apps all running at the same time.
          mp3car live search
            Yeah, that's what I meant.
              To sum it all up... You can't have RR and IGuidance set to the same port. They will both try to access it and RR will win! So... just change the port in RRConfig and you'll be fine.
              Current Setup
              Nexus 7 Tablet
              Built in head unit
              Brutus 1500Watt Amp
              Two Boston 12" subs
              2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
                This worked guys....thanks a million
                  Yeah ditto.
                  Just installed my GPS receiver, IG, ran into the same problem. A Quick "Search" and bingo! All's good.
                    Hey, in RRConfig, what is the "Window Name" for IGuidance? (Not the new 3.0, the older one)
                    Thanks for the help.
                    A car without turbo is a car with perpetual lag.
                    My Ride
                    My New Page
                      they are both the same
                      "iGuidance"
                      mp3car live search
                        Seriously? Damnit, then I guess something else is going wrong.
                        Well, I'll try the com port and see if it does the trick. Thx
                        My Ride
                        My New Page
                          well the lack of a window name will not cause IG to not connect to the gps device. The window name is only used so RR can embed the correct app window.
                          mp3car live search
                            I think what I was doing was opening an iguidance window first, then opening RR and wondering why it would work minimized, but not through the GPS button.
                            My Ride
                            My New Page
