Have to re-run winamp outside RR after hibernate for music to play
  • Have to re-run winamp outside RR after hibernate for music to play
    Hi,
    I know I probably messed up or forgot some setting after I updated to the new (9-5-06) RR yesterday, but basically what I just wrote in the title is what happens. I am playing my music then I hibernate, then when I come back from hibernate, the music wont play (winamp is closed I suppose) so I minimize RR, I double click winamp icon. It opens. I click RR in my taskbar and now I can play my music again... ODD! anyone know what I did wrong ?
    1997 Mazda Miata, Black
    MiataPC
    In-dash Fabrication
    Current dashboard: http://www.aescarpc.com/miatapc/2
    Did you also upgrade to winamp5? There is some plugin in winamp5 that causes this behavior. You have to search the forum and then delete the plugin.
    PowerVoice v1 | NaviVoice Source
    GammaControl v2.4
    SKINbedder v3
    1995 Lexus SC300
      Yeah ive been using 5 for a long time now. I had it with the old version of rr and it didnt do this. ill try downgrading too thogh and see if that fixes the problem
      MiataPC
      In-dash Fabrication
        yeah 0l33l is right..there is a plugin in winamp 5 that causes that..you will have to delete it..it is in the forum somewhere!
          yep, i will try this when i get home and see if it solves the problem
          solution:
          http://www.mp3car.com/vbulletin/show...7&postcount=51
          thanks guys
          MiataPC
          In-dash Fabrication
