Flash expert needed
  • Flash expert needed
    I am trying to change text color from keyboard commands to a flash.exe
    Control+y = Yellow
    Control+b = Blue
    Control+w = white
    So I can activate and sendkey from RR to change colors
    It would probably take me a week to figure this out but some of the people on here could probably do it in 5 minutes.
    I will post the .fla file I am working on if someone wants to give it a shot
    Thx chuck
    ps post 1000
    2001 S10 ZR2
    Chucks Skin - to old
    are you using this flash file as a SWF defined in the .skin file or as an EXE file embedded with the LOAD command ? I'm pretty sure SWF files will not receive keyboard input (so that would not work).
    Ride Runner RR's Myspace
      This is an .exe embedded just to set it in place.
      now i just change exe to change color - funky to watch
      PHP Code:
      "CHUCKSTOP","LOAD;CHUCKSTOP.skin||BYVAR;COLORPICK;RUNTOPYELLOW<<RUNTOPBLUE<<RUNTOPWHITE||EXIT||SHOWWINDOW;ChucksTop;True"
      "CLOSECHUCKSTOP"
      ,"ACTIVATE;ChucksTop||SENDKEY;%{f4}"
      "RUNTOPYELLOW"
      ,"RUN;$CHUCKSPATH$ChucksTopYEL.exe;ChucksTop"
      "RUNTOPBLUE"
      ,"RUN;$CHUCKSPATH$ChucksTop.exe;ChucksTop"
      "RUNTOPWHITE"
      ,"RUN;$CHUCKSPATH$ChucksTopWHT.exe;ChucksTop"
      2001 S10 ZR2
        actually guino i've had success sending keystrokes to flash with the new solid tag. I'll take a look at this for ya chuck. Least i'll try to.. i think my flash trial expired (swishmax FTW!)
        Live mp3Car Facebook Chat
          I don't understand one thing though... I mean, you're MAKING this flash file, so why don't you just have the color in the flash file selected by a global variable you set in RR ? That's what "setflashvar" is for... "SETFLASHVAR;COLOR;2"
          then use:
          if (_root.COLOR == "2") {
          <COMMANDS TO CHANGE THE COLOR/FRAME etc>
          That's coming from someone who knows nothing about flash.. and again that's only useful if there's no special reason why you're using keystrokes to get the job done.
            Here you go Chuck, hope this is what you were looking for.
            But if you test it within the flash ide, make sure you select "Disable Keyboard Shortcuts" from the "Control" menu in the swf preview, or else is won't work.
              then use:
              Will this work with an flash.exe?
              2001 S10 ZR2
                Kembond thanks a bunch
                Works good but every time the time or date changes the color goes back to the startup color
                Almost there
                2001 S10 ZR2
                  Your all set.
                    Kembond thanks a million
                    Works like a champ
                    Now I have a timer to do but I think I can do it from your example
                    Thanks again
                    2001 S10 ZR2
                      :d
                      2001 S10 ZR2
                        No problem,
                        If anything check in the Flash help panel, they have code examples for almost every command.
                          Kembond
                          If you get board and want something to do here is my timer
                          I all most give up
                          2001 S10 ZR2
                            Here you go.
                            I started from scratch, it was easier for me that way.
                            I Let it run for 13 minutes and it worked fine, but you might want to let it run for awhile, at least get an hour.... just to make sure.
                              Kembond you miss understood me
                              The other timer worked fine
                              I was just trying to add the color change thing as the one above
                              2001 S10 ZR2
