Is the PowerMate any good?
  • Is the PowerMate any good?
    so, since I dont have a Touchscreen yet I was thinking of buying a PowerMate knob to control RR with, tried to read though most of the posts already and I've come this far...
    Download girder (last freeware edition)
    Download the PowerMate plugin
    Load the RR.GML file with the release...
    but is the rest as hard to set up as I think... seems lika lots of ppl is having problems, exectbl and so on...
    and one more question, does girder work with flash skins... I'm using freedom and I'm not going to change...
    So, u that have tried it already... is Powermate as good as the looks... (I love the blue light)
    Swedish site for CarPC's
    http://www.bilpc.info
    i use the powermate to control Front Row on my mac and I love it. I've used it on my PC too without issues, but I've read several cases on here where people had trouble with their powermate in windows. I'd say buy it and try it out. If it does work without too much drama then i think you'll come to love it too.
      The only upside to the Powermate is its looks. It fails in every other respect--it's bulky and most do not have a good place for it in their car (and even when they thnk they do, it still looks stupid in a car), it doesn't have nearly enough different inputs, and it's been known to be problematic with hibernation. Also, you want to avoid running girder if possible as it requires a lot of system resources.
      The Shuttle Express is vastly superior because you can mod it and make it an OEM-looking knob on your dash (just that middle part). I found a tutorial on this on this board somewhere a while ago and did it myself.
      Edit:
      Also, this is not the right forum for this.
        I use my powermate with RR and have never gotten it to do more than volume. When I was using frodoplayer, it was easy to use the powermate to scroll up and down through lists, select songs to play, and even pause the music. However, RR doesn't seem to use keyboard shortcuts (at least, as far as I know) so the powermate doesn't interact well without considerable tweakage.
        If someone else knows how to better integrate the powermate with RR, by all means please let me know.
        A car without turbo is a car with perpetual lag.
        My Ride
        My New Page
          Edit:
          Thanks for telling me about that one... I agree on the fact that Powermate doesnt look fully OEM in a car... but hey, so isn't a computer...
          I think it is the right forum since I wanted to know if it was as hard as I thought getting it to work with RR... then why not in the RR forum...
          [edit]
          Just read that the Shuttle express is 4.25" big... thats freaking huge compared to the Powermate... think it would be easier to fit that one...
          Well as I understand it one way is to use girder, there is a RR file for that one with all the different commands from RR, then u just need to learn them into the Powermate or something like that... I tried getting my mouse to work just to figure out the functions in Girder...
            @maxxell: Geez man, that's like slander... you can do so much with it, you'd be surprised, come on just do a few searches. There's people that control literally everything with the powemate, lists, volume, even selection and pressing of buttons -- you can assign clicks, double-clicks, tripple-clicks and even press-n-hold from what I saw... you just have to configure it propperly -- no pain, no gain:
            http://www.mp3car.com/vbulletin/showthread.php?t=72761
            http://www.mp3car.com/vbulletin/show...8&postcount=36 (this one is a STICKY!)
            and for the record, RR can use as many keyboard shortcuts as you want, just define whatever you want in keytbl.ini and it will be available to you, though
            Ride Runner RR's Myspace
              I use the powermate for volume ,scroll the music, pauze, enqeue and esc
              the girder file I have used is this one, very easy to configure to your own settings.
              guino,...
                A powermate and a touchpad in a car not so stupid "deus ex machina" said !
                i don't use RR or Girder but Mediacruiser and Destinator PN.
                The powermate is sufficient for most actions except using virtual keyboard to type an adress.
                The problem with Hibernation can be solved : you must cut +5V alimentation of your powermate when the PC hibernate.
                Use a USB Hub, paste a "scotch" on the USB Cord between motherboard and Hub and use a +5V alim for the hub only when your PC is turned On (I't's easy with M1 or M2 ATX using remote ampli to command a relay)
                  Thanks for both those links... I never realized I would have to edit the keytbl file like that... so I guess since it looks like I'm buying one thats all the changes I need to do to RR files...
                  @Grave
                  nice setup there with the PowerMate btw... good to see one from "the real world" and not only from their site... u cant see the real size of it there...
                  I'll probably put mine infront of the doorhandle in my Volvo... already found a spot for it there...
                    ...and even when they thnk they do, it still looks stupid ...
                      I have a powermate, and only wanted it to control volume to begin with since there is nothing cool about cranking up your volume, while pounding on the touch screen to do it... Since then, i have had it working for volume, track up and down, and a system reboot. Its not that hard to configure, although i did have alot of problems with it crapping the bed on windows xp. It wouldnt start with the system alot of the time, and wouldnt come back after hibernate. Since then i hace installed a pci card with 5 additional usb 2.0 ports. Ive swapped the powermate to one of those ports and havent had a problem since. I think it has to do with the way windows manages its usb connections versus the way this pci card does.... It ahs great functionality, but its liek anything else that is "custom". You have to put time into it to get the results that you want from it.
                      Car Pc progress meter:
                      [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
                      "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
                      My worklog
                        I have one that I bought for an installation and we ended up not using it.
                        I will make you a good deal on it if you want one. It has never been mounted in anything, just bench tested.
                        PM me is you are interested.
                        Nick
                        2002 Twin Turbo ZO6
                        2005 Hummer H2
                          I made my own control knob, from a $9 rotary encoder/8-direction joystick from mouser.com and a 10 button mouse I hacked up.
                          I use girder to take the button presses and send them to RR. It works beatifully
                          it's great for scrolling through playlists and switching songs
                            Nick
                            Thanks for the offer but since I live in Sweden I have a feeling that the shipping will cost more then the PowerMate itself... found it pretty cheap in a store...
                            And a big thanks to the rest of u... it helped me a lot deciding if I should go for a PowerMate or not... going to order it tomorrow...
                              Side note...Girder does not use a lot of system for as long as I have been using it...
                              I even use a plugin(GMR-2K), with it that srinks the mem usage from ~4.3Mb to 168K when it not receiving any commands...
                              Next in line: RRMedia v2.0
                              DFX 5.1.1 Skin
                              Appstore Link
                              My RideRunner Plugins
                              RRMedia
                              RRExtended
                              DFXVoice
