Voice Commands in RR
  • Voice Commands in RR
    Which is the best Voice Command solution for RR ? That can be easily customized and used.
    I installed the latest version of RR and apparently it comes with NaviVoice. I tried using that but had no luck what's so ever. I installed SAPI as mentioned in the manual. Still NOTHING.
    Is there any modification that I need to do in RR.ini ?
    04 Accord Coupe Carputer
    it does not come with navivoice. I already answered this question in the other thread. The built in voice plugin for rr is the best for rr. Read that thread for setup and information
    Live mp3Car Facebook Chat
      When I installed RR, there is a NaviVoice directory in RR folder, which means that it comes with it.
        i dont know what rr install u have but there is no navivoice folder in the official rr binary.
          Then I might be on drugs and must have put it myself . So you think that the other voice control app is better than NaviVoice ? If so, how ?
            its better because its made for RR. Any command you can run with rr you can run with the plugin. Its also still being developed whereas navivoice is well over a year old at this point.
