Utilities/Application Launcher
  • Utilities/Application Launcher
    Is it possible to make the laucher run a non-executable file such as a .reg file? I created 2 directories in the launcher folder and they showed up in roadrunner. I also created .ini files for these in these folders to direct roadrunner to the appropriate files (enablerr.reg and enableexplorer.reg), but nothing happens when I click to run them. Thanks!
    Celeron 2.53 Ghz Processor
    512M ddr memory
    Mimo 7" USB Display
    XM Direct Tuner
    mp3car.com XM Direct USB interface box
    1999 Mustang GT Convertible Supercharged
    You can launch the associated file by doing things like 'regedit enablerr.reg' etc.. or better yet, I'd recommend making a little menu to do that using the run command.
    Ride Runner RR's Myspace
      OK, I'll try the run command. The "regedit rrenable.reg" didn't really work. Didn't do anything. I may just Control Alt Delete and run the script manually from taskman if the run doesn't work. I'm no programmer, so I'll have to see if making the menu is out of my league or not. I do have photoshop 7.0, so I may be able to do something. I don't need anything fancy. Its just so that I can reenable my explorer shell if needed. Thanks again!
      512M ddr memory
      Mimo 7" USB Display
      XM Direct Tuner
