Running a VBScript from a button
  • Running a VBScript from a button
    How can I run a VBScript from a button? I tried Run, RunQ ect,
    Would I need to use wscript.exe, and if so, how would I pass the parameters to it to load the script I want.
    Let's say the VBScript file is named test.vbs
    It would look SOMETHING like this:
    "RUN;wscript.exe,c:\test.vbs"
    (I know the syntax is wrong... as this does not work )
    My Fiero Build Thread
    Try this:
    "RUN;wscript.exe|c:\test.vbs"
    Jarrod - Holden VX S!
      Thanks Jarrod!
      Jarrod Thanks! That did it, I tried a few variations, but never even concidered using a SINGLE Pipe (|), I did try the typical || thought.
      Regardless, that works PERFECTLY, and NOW I can start doing some serious scripting! I am right at home with VBScript!
        From the Skin Commands.txt:
        Code:
        OBS: Anywhere you can run an application you can also specify it's arguments, by using a pipe (|) symbol.
        	Example: "RUN;C:\WINDOWS\NOTEPAD.EXE|c:\t.txt;NOTEPAD;NOTEPAD"
        	(The same can be used within the Launch INI files)
        Glad it worked
          RUN Command
          Hehe I missed the OBS: section entirely.
          I just found the RUN section, and it makes NO mention of that.
          Code:
          "RUN"		- Dynamic Commands: set the code of a button to: "RUN;COMMAND|PARAMETER1|PARAMETER2" will
          		  make it so clicking this button runs the specified command&parameters in the computer.
          		  As an option you can run the command specifying the application name to embed in the current
          		  screen (the application will be enbedded using the "A" settings in the skin file of screen:
          			Example: "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD" (to run embedded)
          		 		 "A,000,055,800,545,000,000,000"   (.skin definition)
          		  Optionally you can also set the text to be "spoken" when clicking the button:
          			Example "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD;NOTEPAD"
            it does say: "RUN;COMMAND|PARAMETER1|PARAMETER2" hehe, which is what you wanted, just didnt explain the parameter part
            either way, its working now! so who cares hehe
